hAP ax2 WireGuard Performance
Hellow
I’m going to update the router, I need to know the wireguard performance of hap ax2, I hope someone has tested and can share the performance.
Thank you
It is better than most other vpns I have tried, so numbers in a sense or not that meaningful, your speed will take a hit regardless.
Should get at least 200-300Mbps depending upon of course the ISPs at either end…
A bit more, I think.
On AX Lite I can reach around 200Mbs TCP and close to 400Mbps UDP using wireguard (internal lab testing to RB5009).
And on that last part, processor of AX Lite was only at 20%, not more. So room for extra load.
Therefore I think AX2 has to be WAAAYY above that.
Im pushing 500mbit TCP on AX3 and CPU load is on 50%.
