Not sure why all the sarcasm feel free if it’s that important, it’s just a basic config. No point in posting the cap as it’s as is in CAP mode nothing to see!
# 2023-11-21 15:36:50 by RouterOS 7.13beta2
# software id = FA8N-TIE6
# model = C52iG-5HaxD2HaxD
# serial number =
add admin-mac=18: auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
/interface wifi
add channel.band=5ghz-ax .frequency=5500-5560 .skip-dfs-channels=10min-cac \
.width=20/40/80mhz configuration.country="United Kingdom" .mode=ap .ssid=\
01 disabled=no name=cap-wifi1 radio-mac=48: \
security.authentication-types=wpa2-psk .encryption=ccmp
add channel.band=2ghz-ax .frequency=2402-2422 .skip-dfs-channels=10min-cac \
.width=20mhz configuration.country="United Kingdom" .mode=ap .ssid=\
01 .tx-power=10 disabled=no name=cap-wifi2 radio-mac=\
48: security.authentication-types=wpa2-psk .encryption=ccmp
set [ find default-name=wifi1 ] channel.band=5ghz-ax .frequency=5180-5240 \
.skip-dfs-channels=10min-cac .width=20/40mhz configuration.country=\
"United Kingdom" .mode=ap .ssid=TEST security.authentication-types=\
set [ find default-name=wifi2 ] channel.band=2ghz-ax .frequency=2462-2482 \
.skip-dfs-channels=10min-cac .width=20mhz configuration.country=\
"United Kingdom" .mode=ap .ssid=01 disabled=no \
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.0.100-192.168.0.200
add address-pool=dhcp interface=bridge lease-time=1d name=defconf
/queue type
add kind=fq-codel name=fq_codel
add kind=cake name=cake
/queue simple
add max-limit=250M/25M name=QOS queue=pcq-upload-default/pcq-download-default \
target=ether1
add disabled=yes max-limit=250M/25M name=fq_codel queue=fq_codel/fq_codel \
target=ether1 total-queue=fq_codel
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 \
path-cost=10
/ipv6 settings
set disable-ipv6=yes
/interface wifi capsman
set enabled=yes
add address=192.168.0.254/24 comment=defconf interface=bridge network=\
192.168.0.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.0.4 client-id=1:84: mac-address=\
84: server=defconf
add address=192.168.0 client-id=1:a0: mac-address=\
A0: server=defconf
add address=192.168.0.0/24 comment=defconf dns-server=192.168.0.x gateway=\
192.168.0.254
/ip dns static
add address=192.168.0.254 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=established,related disabled=yes hw-offload=yes
connection-state=invalid
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
/ipv6 firewall address-list
DELETED....
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/London
/system note
set show-at-login=no
/system package update
set channel=testing
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
