Dear all,
I simplified my configuration a lot.
Just trying to use the hAP as a Layer2 switch.
Ether1 is a trunk port for VLANs 70 and 198, connected to a trunk port on the switch.
The firewall has interfaces in these VLANS, acting as the default gateway for both and also has a DHCP configured on both interfaces
192.168.70.254
192.168.198.254
Ether5 is for hAP management only, connected to the internal network.
Goal:
Different SSIDs INFLUENCER1/2 and IOT1/2 should assign the WLAN clients to different VLANs connecting to different virtual interfaces on the firewall.
Initially I had the same SSID for wifi1 and wifi2, not sure if this was OK or better to separate the two radios?
There are no IP addresses assigned to ether1, bridge (WLAN) nor any of the wifi interfaces.
As mentioned, I want the hAP simply to act as a Layer2 switch, separating the VLANs.
Firewall rules are all disabled.
Current status:
DHCP servers don’t seem to work.
If I assign the IP and default gateway plus DNS manually, I get an Internet connection on IOT1/2, but I don’t get one for INFLUENCER/2.
The interesting part is that I can see the MAC addresses of my phone (used for testing) when checking the ARP entries on the firewall interface???
show arp ethernet1/4.198
maximum of entries supported : 3000
default timeout: 1800 seconds
total ARP entries in table : 5
total ARP entries shown : 5
status: s - static, c - complete, e - expiring, i - incomplete
interface ip address hw address port status ttl
ethernet1/4.198 192.168.198.7 36:e7:f2:91:1f:56 ethernet1/4 c 330
ethernet1/4.198 192.168.198.8 52:a0:8d:41:87:af ethernet1/4 c 377
ethernet1/4.198 192.168.198.12 52:a0:8d:41:87:af ethernet1/4 c 360
ethernet1/4.198 192.168.198.90 b8:27:eb:d1:32:6d ethernet1/4 c 1132
ethernet1/4.198 192.168.198.243 ec:9b:8b:de:5b:1d ethernet1/4 c 637
I tried assigning different static IPs and the phone generates random MAC addresses.
It looks similar to the 70 VLAN ARP table:
show arp ethernet1/4.70
total ARP entries in table : 3
total ARP entries shown : 3
ethernet1/4.70 192.168.70.7 0a:f1:74:aa:c0:4c ethernet1/4 c 96
ethernet1/4.70 192.168.70.8 8e:0e:ac:91:0f:23 ethernet1/4 c 286
ethernet1/4.70 192.168.70.243 ec:9b:8b:de:5b:1d ethernet1/4 c 1385
Configuration:
# 2024-05-20 00:53:43 by RouterOS 7.14.3
# software id = 016R-KMTY
# model = C53UiG+5HPaxD2HPaxD
# serial number =
add name=WLAN vlan-filtering=yes
set [ find default-name=ether1 ] comment=trunk poe-out=off
set [ find default-name=ether5 ] comment=mgmt
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
configuration.country=Switzerland .mode=ap .ssid=INFLUENCER1 \
datapath.bridge=WLAN .vlan-id=198 disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk .connect-priority=0 .ft=\
yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
configuration.country=Switzerland .mode=ap .ssid=Influencer2 \
yes .ft-over-ds=yes
add configuration.mode=ap .ssid=IOT1 datapath.bridge=WLAN .vlan-id=70 \
disabled=no mac-address=7A:9A:18:32:81:70 master-interface=wifi1 name=\
IOTWLAN1 security.authentication-types=wpa2-psk,wpa3-psk \
.connect-priority=0
add configuration.mode=ap .ssid=IOT2 datapath.bridge=WLAN .vlan-id=70 \
disabled=no mac-address=7A:9A:18:32:81:71 master-interface=wifi2 name=\
IOTWLAN2 security.authentication-types=wpa2-psk,wpa3-psk \
.connect-priority=0
add comment=defconf name=WAN
add comment=defconf name=LAN
add include=static name=WLAN1
add bridge=WLAN interface=wifi1 pvid=198
add bridge=WLAN interface=wifi2 pvid=198
add bridge=WLAN frame-types=admit-only-vlan-tagged interface=ether1
/ipv6 settings
set disable-ipv6=yes forward=no
/interface bridge vlan
add bridge=WLAN tagged=ether1 untagged=IOTWLAN1,IOTWLAN2 vlan-ids=70
add bridge=WLAN tagged=ether1 untagged=wifi1,wifi2 vlan-ids=198
/interface detect-internet
set detect-interface-list=all internet-interface-list=all lan-interface-list=\
all wan-interface-list=all
add address=192.168.98.91/24 interface=ether5 network=192.168.98.0
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8,192.168.98.201
disabled=yes ipsec-policy=in,ipsec
disabled=yes ipsec-policy=out,ipsec
connection-state=established,related disabled=yes hw-offload=yes
established,related,untracked disabled=yes
connection-state=invalid disabled=yes
connection-state=new disabled=yes in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set rtsp disabled=no
add check-gateway=ping comment="management Interface Internet access" \
disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.98.2 \
pref-src=192.168.98.91 routing-table=main suppress-hw-offload=no \
vrf-interface=ether5
/ip service
set ssh address=192.168.98.0/24
/ip traffic-flow
set interfaces=ether1
/system clock
set time-zone-name=Europe/Zurich
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=192.168.98.201
add address=192.168.98.208
Interestingly I don’t see all ports in the config, but checking in the CLI I see also IOT1/2:
/interface/bridge/port> print detail
Flags: X - disabled, I - inactive; D - dynamic; H - hw-offload
0 I interface=wifi1 bridge=WLAN priority=0x80 edge=auto point-to-point=auto learn=auto horizon=none auto-isolate=no restricted-role=no restricted-tcn=no pvid=198 frame-types=admit-all
ingress-filtering=yes unknown-unicast-flood=yes unknown-multicast-flood=yes broadcast-flood=yes tag-stacking=no bpdu-guard=no trusted=no multicast-router=temporary-query fast-leave=no
1 I interface=wifi2 bridge=WLAN priority=0x80 edge=auto point-to-point=auto learn=auto horizon=none auto-isolate=no restricted-role=no restricted-tcn=no pvid=198 frame-types=admit-all
2 interface=ether1 bridge=WLAN priority=0x80 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=1
frame-types=admit-only-vlan-tagged ingress-filtering=yes unknown-unicast-flood=yes unknown-multicast-flood=yes broadcast-flood=yes tag-stacking=no bpdu-guard=no trusted=no
3 D interface=IOTWLAN2 bridge=WLAN priority=0x80 edge=auto point-to-point=no learn=auto horizon=none auto-isolate=no restricted-role=no restricted-tcn=no pvid=70 frame-types=admit-all
4 ID interface=IOTWLAN1 bridge=WLAN priority=0x80 edge=auto point-to-point=no learn=auto horizon=none auto-isolate=no restricted-role=no restricted-tcn=no pvid=70 frame-types=admit-all
So in a nutshell my questions are:
- can the hAP act as a simple Layer2 switch?
- Is it correct that I don’t need to assign IP addresses to the wifi interfaces, nor to the bridge nor ether1?
- What PVIDs to use for ether1 and the bridge? Ideally they shouldn’t have any.
- Any idea why I can connect to the Internet from the sub interfaces IOT1/2 but not from the main interfaces on wifi1/2?
- Any idea why the DHCP servers don’t work? Although I could live with that.
Thanks and Regards,
Andreas
