I have the hap ax3 model as my main router, and they gave me another hap ac2 router. I want to put the hap ac2 as CAP, is it possible? If it is, what package do I have to have on Hap ax3, wireless, wifi-qcom-ac, wifi-qcom? and in hap ac2?
Thank you
You don`t have to install any additional Packages on the hAPax3.
You configure Capsman via the WIFI menu, see online documentation
https://help.mikrotik.com/docs/spaces/ROS/pages/224559120/WiFi#WiFi-WiFiCAPsMAN
Having said that, you do need to install the wifi-qcom-ac on the hAPac2 to enable the “WIFI” menu.
Additional, information is also available here.
https://help.mikrotik.com/docs/spaces/ROS/pages/224559120/WiFi#WiFi-Replacing’wireless’package
On the hap ac2 I have already installed the wifi-qcom-ac package. I have activated the CAP option in the wifi menu. Then, on the hap ax3 I have activated CAPsMAN, and in the Remote Cap menu I see the other hap ac2, but it does not pass the wireless configuration. Why could this be?
On the hAPac2,
you need to Configure “Wifi1” and “Wifi2” interfaces to use Capsman
under Configuration-> Manager and select “Capsman”
Hi, thank you. It’s woks fine, but now i have a problem with roaming, there are devices that they connect with hap ac2 instead hap ax3 while they are more nearly to hap ax3. Are there any configuration to improve this situation? or this depends only on the device’s wifi?
Regards
Please share your config:
/export file=anynameyoulike
Remove serial and any other private info.
Hi, this is my configuration without firewall config and others:
# 2025-01-26 10:28:21 by RouterOS 7.17
# software id = 2KEN-HS1Y
# model = C53UiG+5HPaxD2HPaxD
# serial number = XXXXXXXXXXX
add admin-mac=78:9A:18:EA:02:1E auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
set [ find default-name=ether1 ] advertise="10M-baseT-half,10M-baseT-full,100M\
-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full" comment=WAN \
mac-address=78:9A:18:EA:02:1D
set [ find default-name=ether2 ] mac-address=78:9A:18:EA:02:1E
set [ find default-name=ether3 ] mac-address=78:9A:18:EA:02:1F
set [ find default-name=ether4 ] mac-address=78:9A:18:EA:02:20
set [ find default-name=ether5 ] mac-address=78:9A:18:EA:02:21
/interface vlan
add interface=ether1 name="VLAN DATOS" vlan-id=6
add interface=bridge name="VLAN PRUEBAS-VPN" vlan-id=10
add interface=ether1 name=VLAN-VOZ vlan-id=3
/interface pppoe-client
add add-default-route=yes disabled=no interface="VLAN DATOS" name=pppoe-out1 \
service-name=Movistar use-peer-dns=yes user=adslppp@telefonicanetpa
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi configuration
add channel.band=5ghz-ac country=Spain datapath.bridge=bridge disabled=no \
mode=ap name=cfg5GHZ security.authentication-types=wpa2-psk,wpa3-psk .ft=\
yes .ft-over-ds=yes ssid=JUJUMAESIN-PLUS station-roaming=yes
add channel.band=2ghz-n country=Spain datapath.bridge=bridge disabled=no \
mode=ap name=cfg2GHZ security.authentication-types=wpa2-psk,wpa3-psk .ft=\
yes .ft-over-ds=no ssid=JUJUMAESIN station-roaming=yes
/interface wifi
set [ find default-name=wifi2 ] configuration=cfg2GHZ configuration.mode=ap \
disabled=no name=wifi2GHZ
set [ find default-name=wifi1 ] configuration=cfg5GHZ configuration.mode=ap \
disabled=no name=wifi5GHZ security.ft=yes
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=default-dhcp interface=bridge lease-time=8h name=defconf
/ip smb users
add name=miguel
/routing rip instance
add disabled=no name=rip-instance-VOZ redistribute=""
/ip smb
set domain=CASA enabled=yes
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=*6 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=*7 internal-path-cost=10 \
path-cost=10
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-pppoe=yes \
use-ip-firewall-for-vlan=yes
set udp-timeout=10s
/ip settings
set tcp-syncookies=yes
/interface bridge vlan
add bridge=bridge comment="VLAN DATOS" vlan-ids=6
add bridge=bridge comment="VLAN VOZ" vlan-ids=3
add bridge=bridge comment="VLAN PRUEBAS-VPN" vlan-ids=10
/interface detect-internet
set detect-interface-list=all
add interface=ether5 list=LAN
add interface=wireguard-movil list=LAN
/interface ovpn-server server
add mac-address=FE:81:AF:1E:F8:C3 name=ovpn-server1
/interface wifi access-list
add action=accept comment="Pixel 4A Mama-5Ghz" disabled=no interface=all \
mac-address=0E:C4:6D:28:2D:F3
add action=accept comment="Pixel 4A Mama-2Ghz" disabled=no interface=all \
mac-address=0E:0B:89:B8:4A:0E
add action=accept comment="Alexa Echo" disabled=no interface=all mac-address=\
50:DC:E7:27:D1:9F
add action=accept comment="Galaxy A15 Esther-2Ghz" disabled=no interface=all \
mac-address=0A:05:91:C2:2E:BA
add action=accept comment="Pixel 4A Papa-5Ghz" disabled=no interface=all \
mac-address=AE:29:63:84:08:38
add action=accept comment="TV Sony-2Ghz" disabled=no interface=wifi5GHZ \
mac-address=10:B1:DF:4A:A5:D3
add action=accept comment="Motorola G04S Marcos-2Ghz" disabled=no interface=\
all mac-address=16:6B:F8:8D:5A:AC
add action=accept comment="Tablet Galaxy Tab-5Ghz" disabled=no interface=all \
mac-address=4A:E3:55:D7:88:63
add action=accept comment="Nintendo Switch-5Ghz" disabled=no interface=all \
mac-address=94:58:CB:B0:DE:F7
add action=accept comment="Iphone Ines-5Ghz" disabled=no interface=all \
mac-address=D8:BE:1F:81:EE:99
add action=accept comment="MSI Papa" disabled=no interface=all mac-address=\
C0:E4:34:DA:E6:1F
add action=accept
/interface wifi capsman
set enabled=yes interfaces=bridge package-path="" require-peer-certificate=no \
upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=cfg2GHZ \
supported-bands=2ghz-n
add action=create-dynamic-enabled disabled=no master-configuration=cfg5GHZ \
supported-bands=5ghz-ac
192.168.88.0
add address=192.168.0.1/28 comment="Interfaz Wireguard" disabled=yes \
interface=wireguard-movil network=192.168.0.0
add address=172.16.2.1/24 interface="VLAN PRUEBAS-VPN" network=172.16.2.0
add address=172.16.4.2/24 comment="Interfaz WireGuard-Javi" interface=\
wireguardJavi network=172.16.4.0
/ip arp
add address=10.23.64.1 interface=VLAN-VOZ mac-address=00:07:72:B3:F0:94
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=\
208.67.222.222,208.67.220.220 gateway=192.168.88.1
set allow-remote-requests=yes servers=208.67.222.222,208.67.220.220
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add comment="Regla para hacer ping desde la ip del router" distance=1 \
dst-address=172.16.1.1/32 gateway=bridge pref-src=172.16.2.1
/routing rip interface-template
add disabled=no instance=rip-instance-VOZ interfaces=VLAN-VOZ
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name=hap-ax3-Router
/system logging
add topics=wireless,debug
add action=disk disabled=yes topics=ipsec
add disabled=yes topics=ipsec
/system note
set show-at-login=no
Can you adjust according this:
add channel.band=5ghz-ac country=Spain datapath.bridge=bridge disabled=no mode=ap name=cfg5GHZ security=JUJUMAESIN-PLUS-SEC ssid=JUJUMAESIN-PLUS
add channel.band=2ghz-n country=Spain datapath.bridge=bridge disabled=no mode=ap name=cfg2GHZ security=JUJUMAESIN-SEC ssid=JUJUMAESIN
/interface wifi security
add name=JUJUMAESIN-PLUS-SEC authentication-types=wpa2-psk,wpa3-psk ft=yes ft-over-ds=yes connect-priority=0/1
add name=JUJUMAESIN-SEC authentication-types=wpa2-psk,wpa3-psk ft=yes ft-over-ds=yes connect-priority=0/1
/interface wifi
set [ find default-name=wifi2 ] configuration=cfg2GHZ disabled=no name=wifi2GHZ
set [ find default-name=wifi1 ] configuration=cfg5GHZ disabled=no name=wifi5GHZ
This way, you are repeating yourself less. Passphrase is missing, you can add that yourself. Unless you are using accesslists for that (I have no experience with using that for authentication).
Do you want different SSID’s? Because there is no roaming between different SSID’s…
I want SSID to 2Ghz and other to SSID 5Ghz.
