Hap Ax3 compatible with CAP capgi-5acd2nd
Hi everyone!
I have the Mikrotik Hap Ax3 as my main router, I have bought a capgi-5acd2nd to extend the Wi-Fi to my house, because there are places where the Hap Ax3 signal does not reach well. To my surprise, I cannot connect the HAP ax3 and the capgi 5acd2nd to CAPMan. Are they compatible?
If they are not compatible, what do you recommend to extend the Wi-Fi network? Do I sell my cap and buy another ax device, like another CAP ax, hap lite ax3?
Or do I change my ax3 hap for another ac2 or ac3 hap?
https://help.mikrotik.com/docs/display/ROS/Wireless
you need wifi-qcom-ac package on your cap ac. remove wireless package, install wifi-qcom-ac and reset configuration to caps-mode. Done.
I am trying to install the wifi-qcom-ac package in my cap capgi-5acd2nd.
I have downloaded the zip file from the official website. all_packages-arm-7.15.2, and I have unpacked it, I have copied the wifi-qcom-ac-7.15.2-arm.npk file on the system, in files → Upload and I have uploaded the file. I have disabled the wireleess package and restarted the cap, but the package does not load. what am I doing wrong?
Hi again, It’s works. First Uninstall package wireless, and then installa package wifi-qcom-ac and reset configuration and reboot. It’s works package.
