HAP ax3 configuration
Hello, just got my hand on a brand new hap ax3. As i’m new to it and have not really configured much on mikrotik devices can someone please post a good working configuration example for the ax3 so i can get started from some point?
I was use to hap ac and ROS6 but a lot has changed on ROS7 and wifiwave2.
When I started with v7 and wifiwave2 (using Audience which is ac device) I reset unit to defaults (had to as wifiwave2 is optional on audience), only added basic wireless config (SSID and PSK). And performance was already pretty decent. I’ve played a bit since, but I can’t really say tgat it affected performance in my typical use case.
So my advice: go with defaults and do minor tweaks later if needed.
Thanks, found this for wifiwave2
https://help.mikrotik.com/docs/display/ROS/WifiWave2#WifiWave2-Configurationprofiles
Problem is i can’t get 160 mhz to work it just shows me “no channels available”
Have you set country code?
Yup, Estonia.
Ok, can you share your current config (/wireless export)? Make sure to remove the personal info if any. If you place it between code tags it will be most readable.
The only working setup i got working was this.
# jan/08/2023 20:00:23 by RouterOS 7.6
# software id = 6YG9-YNT9
# model = C53UiG+5HPaxD2HPaxD
/interface wifiwave2 channel
add frequency=2412,2437,2462 name=ch-2ghz width=20mhz
add frequency=5180,5260,5500 name=ch-5ghz width=20/40/80mhz
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk group-key-update=1h name=sec1 wps=disable
/interface wifiwave2 configuration
add channel=ch-5ghz country=Estonia mode=ap name=hub-cfg security=sec1 ssid=Hub2
add channel=ch-2ghz country=Estonia mode=ap name=hubz-cfg security=sec1 ssid=Hubz2
set [ find default-name=wifi1 ] channel.frequency=5170-5330 configuration=hub-cfg \
    configuration.mode=ap disabled=no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.frequency=2412,2437,2462 configuration=hubz-cfg \
    configuration.mode=ap security.authentication-types=wpa2-psk,wpa3-psk
It does not matter what channels you set if any. When you select 20/40/80/160 it immediately says no channels available.
By looking at the radios tab i can see that there is no 160 radio listed. Just a wild guess here, but should there be?
hAP AX3 do not support 160 Mhz…only 80 Mhz
What mikrotik device does support 160 mhz?
no device support 160 Mhz at the moment…
