hAP AX3+CRS125-24G the second one is like a switch via wifi
Both devices with version 7.18.2
I need them to be in the same network, the link was via WiFi.
As a result, i can up the link, receive to wlan ip address from DHCP AX3, and then it’s not clear. I can get an IP on the bridge CRS, as well as on the wlan interface. Inside the bridge, the addressing is not given out, regardless of whether i enter wlan into the bridge or not. Separately, any thernet port taken out of the bridge also does not receive ip address.
The issue is aggravated by the sea of ​​disparate information, because the interfaces of different devices and different versions ROS are very different. I would be very grateful if someone could direct me to the appropriate manual. And also, i still don’t understand whether the CRS, with the connection scheme, what i want, will be able to use WiFi for client devices.
Thanks in advance
The question is closed. If someone decides the same thing
  1. Link is possible by radio only in pseudobridge(different radio module)
  2. It is not at all obvious that the interfaces in the bridge are affected by the firewall - masquerading on the WAN
