hAP ax3 does not want to talk to the default gateway
I was tinkering with the wifi interfaces in bridge2 and scanning for my phone's hotspot. I clicked "Connect" then the hAP ax3 doesn't want to talk to the default gateway anymore. This is acting as a bridge, and now wifi1 and wifi2 are disabled. Bridge1 has eth04 and eth05
[wifi ap] <---> [hAP ax3 192.168.11.251/24] <---> [pfsense 192.168.11.254/24] <--->ISP
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, s - STATIC
Columns: DST-ADDRESS, GATEWAY, ROUTING-TABLE, DISTANCE
#     DST-ADDRESS      GATEWAY         ROUTING-TABLE  DISTANCE
0  As 0.0.0.0/0        192.168.11.254  main                  1
  DAc 172.17.0.0/24    containers      main                  0
  DAc 192.168.11.0/24  bridge1         main                  0
Ping to the gw times out:
ping 192.168.11.254
SEQ HOST SIZE TTL TIME STATUS
0 192.168.11.254 timeout
1 192.168.11.254 timeout
2 192.168.11.254 timeout
The default gateway shows in the ARP list.
2 DC 192.168.11.254 XX:XX:XX:XX:XX:XX bridge1 reachable
I see traffic coming in because a pihole is logging requests.
Doing a torch I see this occasionally but the ping times out.
It’s as if IPv4 is not passing but I’m not filtering anything, just accept and forward in the bridge. I’ve moved the wifi AP from the hAP ax3 to the pfsense router.
I’ve rebooted but to no avail, still the hAP ax3 does not want to talk to the default gateway or anything beyond it. Any suggestions?
I’ve reset the configuration and kept users, and this is still not permitting me to communicate to the default gateway:
/interface bridge add name=bridge1
/interface wifi set [ find default-name=wifi1 ] configuration.mode=ap
/interface wifi set [ find default-name=wifi2 ] configuration.mode=ap
/interface list add name=WAN
/interface list add name=LAN
/interface bridge port add bridge=bridge1 interface=ether4
/interface bridge port add bridge=bridge1 interface=ether5
/interface list member add interface=ether1 list=WAN
/interface list member add interface=bridge1 list=LAN
/ip address add address=192.168.11.251/24 interface=bridge1 network=192.168.11.0
The ARP list shows the def gw:
I can ping all the IP addresses listed in the arp but the default gateway. No changes were done to the default gateway and I even rebooted it.
The route looks normal:
> /ip/route/print
What else can I share?
The configuration is shared with /export and inserted into </> after selecting all the text, not line by line.
(redacting serial number, passwords and real IPs)
Aside from that, deleting the configuration also deletes the default route (and also the DNS).
Then for the rest the topic seems confusing enough to me to not understand exactly what is intended to be done,
and above all, what has already been done.
A guess: you want to configure hAP ax3 as transparent bridge between wireless and ethernet parts of your LAN. And that would mean you need to add both wifi and ether ports to same bridge.
If that's not it, then explain in details intended role of hAP ax3 and post full configuration export ... because snippets (of what you think is a problem) don't show the full picture (often in these discussions it turns out that problem is elsewhere ... and you as person asking for help are clearly not in position to decide which part of config is wrong or else you'd probably know how to fix it in the first place).
What I've done since is simplify everything in the previous post. I moved all the wifi AP connections and directly connected them to the pfsense router. My laptop is plugged into the pfsense router. The pfsense router is the gateway (192.168.11.254). No changes were made to the pfsense for this incident.
The hAP now has a very simple configuration after a reset:
add name=bridge1
/interface wifi
add name=WAN
add name=LAN
set servers=192.168.11.254
add action=accept chain=forward
add gateway=192.168.11.254
Consider now the hAP ax3 as a node. I can ping it from my laptop, I can connect to it via winbox. From the hAP ax3 I can see several devices from the ARP list and ping them, all except the pfsense router.
I've got wifi1 and wifi2 disabled. Only way in or out of the hAP ax3 is in ether5, connect to the pfsense router.
My laptop and other devices ping the pfsense router just fine, it's just the hAP ax3 that can not. This I find very strange.
I don't see any problem with the configuration, if it's really as you explained.
Change the IP address to see if there's a firewall rule blocking IP .251, just in case.
To test, remove the IP, Route, and DNS and use the DHCP client on bridge1.
If it doesn't work, the problem is elsewhere, not on the RouterBOARD.
I have a dhcp server on the pfsense, so I made the hAP ax3 a DHCP client so the configuration is now:
add name=bridge1
/interface wifi
add name=WAN
add name=LAN
set lldp-poe-power=no protocol=""
/ip dhcp-client
add default-route-tables=main interface=bridge1
I did turn off discovery protocol for a IoT device that doesn't like discovery.
Now the hAP ax3 can ping the pfsense router.
So I must've been missing something so basic. Very strange, or using the dhcp client kind of reset the ip4 stack? Again, no changes to the pfsense router, only the hAP ax3.
But now you have BOTH the DHCP client AND the static IP added to the bridge.
What is the output of:
/ip address print
For example, pfsense might not accept manually assigned IP addresses,
but only devices that have been assigned an IP address by the DHCP server.
Pfsense will accept a manually assigned address. The event when communication stopped with the pfsense router was when I clicked "connect" on a wifi interface. Everything was working fine up until then.
Now, to somewhat reset the interface bridge1, I've had to convert it to a dhcp client, even if momentarily. I might keep it this way.
But what is the intent of wifi on hAP ax3?
As it is now, it will accept wifi connections from stations. But those stations won't be able to receive IP settings (because wifi interfaces are not part of L2 network, spanning pfsense with its DHCP server nor there's a DHCP server running on hAP ax3) ... and even if those stations are configured with manual IP setup, they won't be able to communicate with the rest of LAN (and beyond) because (again) wifi interfaces are not part of same L2 network as the rest of LAN and neither is hAP ax3 configured to route between wifi interfaces and the rest of LAN.
The intent of the hAP ax3 is to monitor the wifi, host an SMB share, and run a pihole container. Eventually the wifi AP will be connected to the bridge1, then things will be back to normal.
I made it over the big hump of getting the hAP ax3 to talk to the pfsense router. Why it took changing from a static IP to a dhcp client I don't know. But I could stay at a dhcp client. I have options.
Now my next issue is getting a pihole image to repull since pasting in the container commands from a export doesn't seem to recreate the container and pull. The container wants to pull but I get:
pihole: import error: check url failed: ssl: no trusted CA certificate found (6)
Small issues, hopefully easily overcome.
