hAP ax3 - Lastest firmware ![]()
Since RouterOS 7.13 , they had added that /interface/Wifi section.
My router’s wireless was setup directly from the wireless interface.
What would my best way to stop using the interface directly, and take advantage of Wifi ? Would best be just to Reset the wireless interfaces , and setup wireless from the wifi panel ?
Seems to be alot more options under /interface wifi. than /interface/wireless .
Here is my current config
# 2025-02-20 12:36:00 by RouterOS 7.17.2
# model = RBD53iG-5HacD2HnD
add admin-mac=DC:2C:6E:5A:56:A8 auto-mac=no comment=defconf name=bridge port-cost-mode=short
add name=bridge2 port-cost-mode=short
set [ find default-name=ether1 ] rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether2 ] rx-flow-control=on tx-flow-control=on
set [ find default-name=ether3 ] comment=xbox rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether4 ] rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether5 ] rx-flow-control=on tx-flow-control=on
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
/interface wifi channel
add band=5ghz-ax disabled=no name=wifi6AX width=20/40/80mhz
add authentication-types=wpa2-psk mode=dynamic-keys name=wpa2 supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=1 band=2ghz-b/g/n channel-width=20/40mhz-XX country="united states3" disabled=no installation=indoor mode=\
ap-bridge security-profile=wpa2 ssid=homenet2 wireless-protocol=802.11
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=0 band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no frequency=auto installation=indoor mode=ap-bridge \
security-profile=wpa2 ssid=homenet5 wireless-protocol=802.11
add name=wired-pool ranges=10.0.0.2-10.0.0.254
add address-pool=wired-pool interface=bridge2 lease-time=10m name=dhcp2
/ip smb users
/queue tree
add disabled=yes name=eth-cakewalk parent=ether2
/queue type
add kind=cake name=cakekind
add kind=pcq name=download-test-pcq
add kind=fq-codel name=fq-codel
/queue interface
set ether1 queue=default
set ether2 queue=cakekind
set ether3 queue=cakekind
set wlan1 queue=cakekind
set wlan2 queue=cakekind
/queue simple
add max-limit=10M/900M name=openthrottle queue=cakekind/cakekind target=wlan2 total-queue=cakekind
add max-limit=5M/900M name=cake queue=cakekind/cakekind target=wlan1 total-queue=cakekind
add max-limit=50M/900M name=bufferbloat-test-cake queue=cakekind/cakekind target=ether2 total-queue=cakekind
add disabled=yes name=xbox- queue=cakekind/cakekind target=ether3 total-queue=cakekind
add address-pool=default-dhcp insert-queue-before=cake interface=bridge lease-time=10m name=defconfdhcp1
/queue tree
add disabled=yes name=queue1-fq-ocodel parent=wlan2 queue=fq-codel
add disabled=yes name=wlan2-cakewalk parent=wlan1 queue=cakekind
add disabled=yes name=global-que parent=global queue=fq-codel
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-protocol=SHA1 encryption-protocol=AES security=private write-access=yes
add addresses=::/0 disabled=yes name=PRTG
/system logging action
set 3 remote=10.0.0.2
add bridge=bridge2 comment=defconf ingress-filtering=no interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2 internal-path-cost=10 path-cost=10
/interface bridge settings
set use-ip-firewall=yes
set udp-timeout=10s
/ipv6 settings
/interface detect-internet
set detect-interface-list=all internet-interface-list=all lan-interface-list=all
add comment=defconf2 interface=bridge2 list=LAN
/interface ovpn-server server
add auth=sha1,md5 mac-address=FE:3D:CF:FD:92:58 name=ovpn-server1
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=10.0.0.1/24 comment=hardwiredpcs interface=bridge2 network=10.0.0.0
add address=98.164.6.235/22 interface=ether1 network=98.164.4.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.240 client-id=1:d8:e2:df:19:c3:9f mac-address=D8:E2:DF:19:C3:9F server=defconfdhcp1
add address=10.0.0.0/24 comment=wiredpcsnet gateway=10.0.0.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip hotspot profile
/ip ipsec profile
/ip service
set ssh disabled=yes
set www-ssl disabled=no
/ip smb shares
set [ find default=yes ] directory=/pub
/ip traffic-flow
set active-flow-timeout=1m interfaces=wlan2,ether3
/ip traffic-flow target
add dst-address=10.0.0.2 v9-template-refresh=30 v9-template-timeout=30s version=ipfix
/routing bfd configuration
add disabled=no
/snmp
set contact=brandontict@gmail.com enabled=yes location=Kansas trap-version=3
/system clock
set time-zone-name=America/Chicago
/system identity
set name=RouterOS
/system leds
set 4 interface=wlan2 type=interface-status
set 5 interface=wlan2 type=wireless-signal-strength
/system note
set show-at-login=no
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
/tool traffic-monitor
add interface=bridge name=trafficmon
/interface wireless
/interface wireless
[admin@RouterOS] /interface/wireless>
/interface wifi - I had added a channel / band , and nothing else
[admin@RouterOS] /interface/wifi> export
