Hap ax3 no wifi
i have got new Hap ax3 and im trying to config wifi The 5G is never seen. Tried enable/disable; no success. Reboots don’t help. still no Wifi and/or intermittent 2.4 advertisement but unable to connect.
Running 7.20 Stable release.
Wifi1 and Wifi2 show SMB in the Wifi config tab, but in the Interface tab only show SMB
i also noted there is USA and Canada only when choosing country from quick set
my config
# 2026-01-05 14:08:02 by RouterOS 7.20.6
# software id = 9308-UN5N
# model = C53UiG+5HPaxD2HPaxD
# serial number = Hremoved
add admin-mac=04:F4:1C:8E:27:E7 auto-mac=no comment=defconf name=bridge
/interface wifi
set \[ find default-name=wifi1 \] channel.band=5ghz-ax .skip-dfs-channels=\\
    10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=TOYOU5G \\
    disabled=no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes \\
    .ft-over-ds=yes
set \[ find default-name=wifi2 \] channel.band=2ghz-ax .skip-dfs-channels=\\
    10min-cac .width=20/40mhz configuration.mode=ap .ssid=TOYOU4G disabled=no \\
    security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add address=192.168.88.1/24 comment=defconf interface=bridge network=\\
    192.168.88.0
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=\\
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment=\\
    "defconf: accept established,related,untracked" connection-state=\\
add action=drop chain=input comment="defconf: drop invalid" connection-state=\\
    invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN" \\
    in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy" \\
    ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" \\
    ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" \\
add action=accept chain=forward comment=\\
    "defconf: accept established,related, untracked" connection-state=\\
add action=drop chain=forward comment="defconf: drop invalid" \\
    connection-state=invalid
add action=drop chain=forward comment=\\
    "defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \\
add action=masquerade chain=srcnat comment="defconf: masquerade" \\
/ipv6 firewall address-list
add address=2001![:10:](https://emoji.slack-edge.com/T3CCNJ7GE/10/6dd1a7564f3be1a0.png):/28 comment="defconf: ORCHID" list=bad_ipv6
/ipv6 firewall filter
    invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=\\
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \\
    dst-port=33434-33534 protocol=udp
    "defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=\\
    udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 \\
    protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=\\
    ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=\\
    ipsec-esp
add action=drop chain=input comment=\\
    "defconf: drop everything else not coming from LAN" in-interface-list=\\
    !LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \\
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" \\
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=\\
    icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=\\
    500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=\\
    ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=\\
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Asia/Riyadh
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=\*sys \\
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \\
    source="\\r\\
    \\n   :if (\[system leds settings get all-leds-off\] = \\"never\\") do={\\r\\
    \\n     /system leds settings set all-leds-off=immediate \\r\\
    \\n   } else={\\r\\
    \\n     /system leds settings set all-leds-off=never \\r\\
    \\n   }\\r\\
    \\n "
add comment=defconf dont-require-permissions=no name=wps-accept owner=\*sys \\
    source="\\r\\
    \\n   :foreach iface in=\[/interface/wifi find where (configuration.mode=\\"a\\
    p\\" && disabled=no)\] do={\\r\\
    \\n     /interface/wifi wps-push-button \\$iface;}\\r\\
    \\n "
/tool mac-server
/tool mac-server mac-winbox
FT doesn't make sense, why enable it? Or better...why use different SSID's?
Did you do configure through Quick Set?
In regards to USA/Canda: sounds like it is US only device. You are not in the USA (or Canada)?
And at last...the 5G radio. What status is it? Could be that it is waiting for a minute in case a DFS channel was chosen.
im not in us or canada is that will effect 5G wifi?
and regarding config i tried all possible why not only quick config
i try use same ssid and different ssid wifi always not working
even when 2.4g visible its somehow not working
(fixed code quotes and removed serial)
There shouldn't be a US-only version for this model. At least not according to product pages.
Set frequency manually.
I know 7.20 should by default deprioritize UNII-3 channels but I prefer to set the frequency manually so I KNOW where it should be.
What is it set to now ? You should see it on wifi settings.
Same remark. It doesn't make sense at all.
