Hap AX3 - Poor Wifi throughput
I know this has been mentioned to death. I have 2x hAP ax3 just for testing and no matter what I just can’t get over 40Mbps wifi performance without having an open SSID. I’ve tried many different channels power going all the way down to 6 along with antenna gain. I’m hoping it’s something I just keep over looking. I’m not a wifi guy but more an enterprise routing guy. I have the hAP’s as just AP’s really connected to a CRS with PoE that is connected to a CCR2116 that is my router. I have roughly 60 wireless devices in my house and my EAP-660HD’s regularly get up to 800Mbps throughput over 5G (I know they are 4x4 and better overall). I’ve not bothered with CAPsMan yet but I plan to have it running on the CCR2116 somewhere down the line if I can ever get these AP’s working better than my old 802.11G equipment. I’ll try almost anything to get these working better. I have them located in the extreme edges of my house and want to use them for my kids Xbox’s. Below is my config from one of my hAPs.
# 2023-11-02 19:45:05 by RouterOS 7.11.2
# software id = 97NZ-0N3F
# model = C53UiG+5HPaxD2HPaxD
# serial number = HE308H8AW2S
add admin-mac=48:A9:8A:55:99:FC auto-mac=no comment=defconf name=BR-LAN protocol-mode=none
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=all .width=20/40/80mhz configuration.antenna-gain=6 .country=\
    "United States" .mode=ap .ssid=MT-BR .tx-power=22 disabled=no security.authentication-types=wpa2-psk,wpa3-psk .encryption=""
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=all .width=20/40mhz configuration.antenna-gain=6 .country=\
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment="trying to figure this out" name=Testing
/interface wifiwave2 channel
add band=5ghz-ax disabled=no frequency=5160-5340 name=5Ghz skip-dfs-channels=10min-cac width=20/40/80+80mhz
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec1
/interface wifiwave2 configuration
add antenna-gain=6 channel.skip-dfs-channels=all country="United States" datapath.bridge=BR-LAN disabled=no mode=ap name=WiFi-CFG \
    security=sec1 security.authentication-types=wpa2-psk,wpa3-psk ssid=MT-BR tx-power=22
add bridge=BR-LAN comment=defconf interface=ether2
add bridge=BR-LAN comment=defconf interface=ether3
add bridge=BR-LAN comment=defconf interface=ether4
add bridge=BR-LAN comment=defconf interface=ether5
add bridge=BR-LAN comment=defconf interface=wifi1 point-to-point=no
add bridge=BR-LAN comment=defconf interface=wifi2 point-to-point=no
add bridge=BR-LAN interface=ether1
/ip settings
set accept-redirects=yes accept-source-route=yes
/ipv6 settings
set disable-ipv6=yes max-neighbor-entries=15360
add comment=defconf interface=BR-LAN list=LAN
add interface=ether1 list=WAN
add address=192.168.10.5/24 interface=BR-LAN network=192.168.10.0
/ip dhcp-relay
add dhcp-server=192.168.10.1 disabled=no interface=ether1 name=relay1
set servers=8.8.8.8
/ip dns static
add action=fasttrack-connection chain=input connection-state=established,related hw-offload=yes
add action=accept chain=input
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=BR-LAN type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=America/Chicago
/system identity
set name=MT-hAPax3-Bdrm
/system note
set show-at-login=no
/system ntp client
set enabled=yes mode=manycast
/system ntp client servers
add address=192.168.10.136
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
What happens if you simply reset to default, only change bridge config, dhcp settings etc… to make it simply AP and not touch wifi settings ?
Try to set frequency manually after scanning the area where the device is to be located.
Then work from there.
