I hear very strange noise from inside my new hap ax3. It looks like a working of small fan (but as I know there isn't fan). It not a very loud, from distance over 40-50cm it unheared totally. Sound is appering after router is full booted up. I tried differents psu’s but it not help.
That does sound weird. It almost sound like something is shorted and internal power supply is in hiccup mode. Or like something is arcing internally but at only 24V I doubt it…
Router is working normally ? Did you check if USB is working ? Antennas are tightly screwed ?
Sadly, a couple of hours ago I got answer from my distributor that is the variant of coil/inductance whine and it's acceptable. They doesn't devices exchange without any malfunctions in functionality.
Usually it can be dampened putting some (specific for electronics, not the bathroom acetic kind) silicone caulking paste around it, but likely if the device is new opening it/modifying it will void your warranty.
What usually works good is hot glue if the component doesn’t get very hot. But yea, if it’s just a coil whine then it’s nothing serious and it’s not loud at all so I would leave it as is.
I got answer from mikrotik official support today about this issue:
If the device is still covered by warranty, please follow one of the options below:
If you have purchased this device directly from MikroTik, please use the RMA system in your distributor account and start a warranty process by referring to this support ticket with a precise "Problem" name and "Problem description".
If the device was not bought directly from MikroTik, please contact the distributor or the company you bought the device from, and ask for RMA warranty repair and further instructions.
The sound produced by the device is not expected during normal operation and typically indicates a hardware fault.
If the device is still covered by warranty, please contact the distributor or the company you bought the device from, and ask for RMA warranty repair and further instructions.
This is actually quite common. With a good ear and in sufficiently silent surroundings you can hear quite a few bits of electronics.
Whether yours is within the normal range or not cannot really be determined over the Internet.
I think you (and support) made the right call - if this is sufficiently more pronounced than other electronics you have, that is a cause to return it. That said, it probably wouldn't affect the life or functioning of the device.
Most of the time you get rejected because coil whine doesn’t affect device operation, it’s just annoying.
Similar thing is with dead pixels on monitors. You need to have certain percentage of dead pixels in order to get your screen replaced. That also depends from manufacturer to manufacturer.
Never knew about that… I had dead pixels twice and only one pixel was dead almost in the middle of the panel. It was super annoying and when I tried to claim warranty they said to me that certain percentage must be dead… Probably referring to what you posted.
