hap ax3 wifi problem
hello, the hap ax3 v(7.12) the problem is that when i add a virtual interface wifi on 2.4 ghz its not showing in the air when searching for wifi signal
i tried to change the frequency even the real interface wifi signal of 2.4 disapear ,but the 5ghz work fine even with virtual its work fine
another problem when using hotspot on any interface of wifi its stop showing in the air so what is the problem is it the software problem or hardware i just bought it 3 days ago so do i do a refund or i wait to sloution
A virtual interface uses the same frequency as its master. Per radio there is only one frequency possible.
Did you do a complete config of the virtual interface (at least SSID)? Can you share your config?
/export file=anynameyoulike
Remove serial and any other private information. And place the export between code tags (using the </> button).
i did do the simple configuration and i have 3 wifi signal now with two vrf network as i said its work fine with 5ghz but not with the 2.4
i removed the hotspot configuration and the 4th signal i can provide you with anydisk so you can remotly see it
LET ME SIMPLIFY THE PROBLEM FOR YOU WHEN I ADD A VIRTUAL WIFI ON 2.4 INTERFACE AND APPLY HOTSPOT CONFIGURATON ON THE NEW VIRTUAL WIFI ,ITS NOT SHOWING UP IN WIRELESS SEARCHING AND LET SAY ITS LIKE STOP WORKING—THE VIRTUAL WIRELESS ENTER WITH VRF AND ROUTING TO SPICIFIC LINE WHEN I REMOVE IT FROM VRF ITS WORK AND SHOWS UP WHEN ENTER THE VRF NOT SHOWING UP AND NOT WORKING
