Anybody has problems connecting MacBooks over WiFI with hAP be lite? I tried with MacBook Air M1 and M4. Even 7.24rc firmware, no luck. Disabled MLO as well. I always get "The Wi-Fi network 'xx' could not be joined". iPhone's also cant join the wifi network. Most Windows laptops are ok, as well as Android phones.
Sounds like typical MickeyMouseaKeTosh not following/respecting standards (as usual) from here, since everything else seems to work.
Do a search - this has been a frequent topic, and likely the same solution as on ax . . . .
Make sure you did not use WinBox 3.x to edit the WiFi setting. Check the recent forum threads related to interworking.realms-raw, for example:
You need to use WinBox 4 or the CLI when editing the WiFi settings.
For me, iPhones work with hap be lite.
First of all, thank you for help and ideas! I didn't pushed newer firmware on existing AX box, so didn't have interworking.realms-raw problems.
Strange, very strange, /interface wifi configuration
unset value-name=interworking.realms-raw [find] didn't help at first. Then I switched channel settings to Ce and Macs found the WiFi. What strange is, I set back to standard channel settings and now is also working. Hmm.
Wireless stations tend to remember a few properties of a SSID and if they determine they can not work with certain SSID, then those properties either have to change or they have to be made to "forget" the network.
It is possible that changing channel settings made Macs to forget previously cached properties about unsuitable SSID ... while changing interworking.realms-raw didn't.
