Anyone got an idea why my Hap be Lite keeps locking up? I've started from scratch with a bridge, dhcp client on the bridge and all ports bridged together. Wifi is 5ghz ax and 2.5ghz ax, and it works. The after a while it just stops. It's driving me mad. I had to send one back because the 5ghz radio stopped working entirely, and now this one is unreliable. I've configured wifi settings straight onto the interface (removing Mld entirely) because that seemed to bork it. Tried it with 7.25.1, now trying 7.26b5. Neither make any difference.
Thank in advance.
2026-11-03 17:41:18 by RouterOS 7.26beta5
software id = PIG2-C0IZ
model = A42G-HbeP
serial number =
add name=bridge1
/interface wifi
add mac-address= mld-name=mld-** name=mld1
set [ find default-name=wifi1 ] channel.band=2ghz-ax .frequency=2300-75000
.skip-dfs-channels=all .width=20mhz configuration.country=
"United Kingdom" .mode=ap .ssid=***** disabled=no
security.authentication-types=wpa2-psk,wpa3-psk .encryption=ccmp,gcmp
set [ find default-name=wifi2 ] channel.band=5ghz-ax .frequency=2300-75000
.skip-dfs-channels=all .width=20/40mhz configuration.country=
"United Kingdom" .mode=ap .ssid=******** disabled=no
/ip dhcp-client
add interface=bridge1 name=client1
set allow-remote-requests=yes
/system clock
set time-zone-name=Europe/London
/system identity
set name=WifiHapBeLite
/system leds
set 0 interface=bridge1
add bridge=bridge1 interface=wifi1
add bridge=bridge1 interface=wifi2
