hAP be lite - MLO - Checking my work
I would like to check my work regarding the wireless radios on my hAP be lite - I have finally found the problem that has been plaguing this router since I upgraded (and then subsequently downgraded) from 7.25, to 7.24.6.
That is: MLD, and tying the 5GHz and 2.4GHz radios to it completely broke stable client connectivity (of all generations, all at the same time as each other).
This is the current configuration on my wireless router:
inter/wifi/configuration/print
0  name="cfg-private" country=United Kingdom ssid="NR36" mode=ap
1  name="cfg-open" country=United Kingdom ssid="NR36 Open" mode=ap
   datapath=dp-open datapath.bridge=bridge1 .client-isolation=yes .vlan-id=10
2  name="cfg-iot" country=United Kingdom ssid="NR36 IoT" mode=ap security=sec-iot
   security.wps=disable .authentication-types=wpa2-psk datapath=dp-iot
   datapath.bridge=bridge1 .vlan-id=313
3  name="cfg-general" country=United Kingdom installation=indoor mode=ap
inter/wifi/registration-table/print
Flags: A - AUTHORIZED
Columns: INTERFACE, SSID, MAC-ADDRESS, UPTIME, LAST-ACTIVITY, SIGNAL
#   INTERFACE                  SSID      MAC-ADDRESS        UPTIME  LAS  SIGNAL
0 A WLAN (2.4GHz)              NR36      BC:F1:05:9D:77:18  1h50s   0ms  -44
1 A WLAN (5GHz)                NR36      E8:78:29:C4:B7:3B  54m9s   0ms  -66
2 A WLAN (5GHz)                NR36      E2:BE:D8:8D:60:24  18m22s  0ms  -57
3 A vWLAN - NR36 IoT (2.4GHz)  NR36 IoT  AE:96:26:07:39:1A  13m22s  0ms  -47
inter/wifi/print
Flags: M - MASTER; B - BOUND; X - DISABLED, I - INACTIVE, R - RUNNING
Columns: NAME, MASTER-INTERFACE, CONFIGURATION.MODE, CONFIGURATION.SSID,
         CHANNEL.WIDTH
#     NAME                        MASTER-INTERF  CO  CONFIGURA  CHANNEL.WIDTH
0 MBR WLAN (2.4GHz)                              ap  NR36       20mhz
1 MBR WLAN (5GHz)                                ap  NR36       20/40/80mhz
2   I mld0                                       ap
3  BR vWLAN - NR36 IoT (2.4GHz)   WLAN (2.4GHz)  ap  NR36 IoT
4   X vWLAN - NR36 IoT (5GHz)     WLAN (5GHz)    ap  NR36 IoT
5   X vWLAN - NR36 Open (2.4GHz)  WLAN (2.4GHz)  ap  NR36 Open
6   X vWLAN - NR36 Open (5GHz)    WLAN (5GHz)    ap  NR36 Open
inter/wifi/print detail
0  MBR default-name="wifi1" name="WLAN (2.4GHz)" mac-address=D0:EA:11:D5:73:E8 arp-timeout=auto radio-mac=D0:EA:11:D5:73:E8 configuration=cfg-private configuration.ssid="NR36" .mode=ap
       .country=United Kingdom security=sec-private security.wps=disable .authentication-types=wpa2-psk,wpa3-psk datapath.bridge=bridge1 .vlan-id=303 channel=ch24 channel.band=2ghz-be
       .width=20mhz
1  MBR default-name="wifi2" name="WLAN (5GHz)" mac-address=D0:EA:11:D5:73:E9 arp-timeout=auto radio-mac=D0:EA:11:D5:73:E9 configuration=cfg-private configuration.ssid="NR36" .mode=ap
       .country=United Kingdom security=sec-private security.wps=disable .authentication-types=wpa2-psk,wpa3-psk datapath.bridge=bridge1 .vlan-id=303 channel=ch5 channel.band=5ghz-be
       .width=20/40/80mhz
2    I name="mld0" mac-address=D2:EA:11:D5:73:E9 arp-timeout=auto mld-name="mld0" configuration=cfg-general .mode=ap .country=United Kingdom security=sec-general security.wps=disable
       datapath=dp-general datapath.bridge=bridge1
3   BR name="vWLAN - NR36 IoT (2.4GHz)" mac-address=D2:EA:11:D5:73:E8 arp-timeout=auto master-interface=WLAN (2.4GHz) configuration=cfg-iot configuration.ssid="NR36 IoT" .mode=ap
       .country=United Kingdom security=sec-iot security.wps=disable .authentication-types=wpa2-psk datapath=dp-iot datapath.bridge=bridge1 .vlan-id=313
4    X name="vWLAN - NR36 IoT (5GHz)" mac-address=D2:EA:11:D5:73:EA arp-timeout=auto master-interface=WLAN (5GHz) configuration=cfg-iot configuration.ssid="NR36 IoT" .mode=ap
       .country=United Kingdom security=sec-open security.wps=disable .authentication-types=wpa2-psk datapath=dp-open datapath.bridge=bridge1 .vlan-id=10
5    X name="vWLAN - NR36 Open (2.4GHz)" mac-address=00:00:00:00:00:00 arp-timeout=auto master-interface=WLAN (2.4GHz) configuration=cfg-open configuration.ssid="NR36 Open" .mode=ap
       .country=United Kingdom security=sec-open security.wps=disable datapath=dp-open datapath.bridge=bridge1 .client-isolation=yes .vlan-id=10
6    X name="vWLAN - NR36 Open (5GHz)" mac-address=00:00:00:00:00:00 arp-timeout=auto master-interface=WLAN (5GHz) configuration=cfg-open configuration.ssid="NR36 Open" .mode=ap
Essentially, the CURRENT configuration works. What I want to understand is how to configure MLO correctly. This is a Wifi7 device, and therefore I want my other Wifi7 capable devices (only a Galaxy S24 Ultra so far) to be able to use Wifi7, without it breaking literally everything.
What I believe the catalyst to have been for this issue occurring initially is the upgrade path from 7.24 to 7.25. When that didn't work, I went to LTS instead of Stable, in the hopes that I could regain some stability.
Thanks!
Please try next:
row 2: Change mld-name="mld0" in something like mld-name="mld-mac_address"
row 0 and 1: add mld-interface=mld0
Hope this will help.
Edit:
Also change master-interface=WLAN (5GHz) into master-interface=wifi2 and master-interface=WLAN (2.4GHz) into master-interface=wifi1
So will those suggestions make a difference I wonder?
Currently, naming scheme aside, this is a working configuration. What is more confusing, is that my S24 Ultra has detected this wireless connection as 'wifi7'. This is all while the two radios do NOT have an MLD interface configured, despite the mld0 interface being enabled.
