hAP Lite as switch + AP Client
Hi!
I’d like to use hAP Lite for most of the time simply as switch: sharing one Ethernet socket in the wall (eg. lan1) into two devices (lan2, lan3) with static IP addresses: computer and printer. This is the switch part.
Occasionally I’d like to bring all of it out of the office, enable hotspot in phone and automatically provide internet for computer and printer, without even logging into router. It will be used by persons completely not familiar with all this stuff.
I think about setting AP Client configuration in hAP, looking for certain AP name and - if found - logging into it using certain password. If WiFi is available - both devices uses internet, having still the same static IP addresses (lan2, lan3).
If WiFi is not available - hAP works like a switch, described at the beginning.
I’ve tried to use Quickset, but changing from ‘Home AP’ to ‘CPE’ causes reconfiguration and I’ve lost connection.
What do you suggest?
Ok, I’ve upgraded router firmware to the latest and above problem disappeared.
Currently my hAP works in CPE configuration.
  1. LAN router works ok: both devices with static IP works ok connected to the Ethernet socket in the wall.
  2. WiFi router doesn’t work: both devices can see themselves, Wifi is connected, but devices doesn’t have internet.
    Below screens from WebFig:
    https://ibb.co/xL7xF3t
    https://ibb.co/V39CYfp
    https://ibb.co/c1RVZqr
    What to to to have internet in case of Wifi connection?
The problem you have is that both devices have statically set default gateway (e.g. 192.168.88.1). But that host is not available when your little setup becomes island connected via phone hotspot.
If you want to have both machines working without any change, hAP would have to change its own IP address to the one of usual gateway (or add it to its usual one). I’m sure this could be achieved using some script which would check internet access via wireless interface and if there is access, add (or change) bridge address. And drop it (or change back) when internet via wireless is not available anymore. Ideally you would monitor availability of “real” gateway … because if hAP would be connected to your usual LAN and with wireless connectivity to internet, it should use default gateway IP address as in this case two devices in the same network would use same address.
