hAP Lite bad wifi performance [FIXED]
Is anyone experiencing very bad wifi performance on hAP Lite?
No matter what device I use, or good my signal is, I can’t get more than 20Mbit.
I’ve already done this command but that didn’t work
interface wireless reset-configuration
Settings? I have no problem over 90Mbit on speedtest
what datarates report the client on registration table with that performance??
150Mbit.
I have only 150Mbit wireless card in notebook
Well it’s fixed I think, I forgot to re-enable chain 1 and 802.11n after I reset the config. I’m getting 60-80Mbit now :smiley:
ok, take in count thats using 40mhz channel not every environment allow that 2.4 ghz its crowded in many sites
Hello, Everybody.
I bought a new MikroTik hAP lite router, but Im a beginner about the configuration.
Please I need some help to make my router work.
Can someone help me? Or give me a tutorial, which is understandable and good, because I saw some tutorials on the internet but none of them were good. I had to reset my router 'cause I misconfigured something.
The device is configured when you buy it. Just plug the cables and use it. What do you want to configure?
No its not working. I can only access my routers homepage to configure.
Good, if you found the router webpage, you are on the right track. Now all you need to do, is enter the settings from your ISP on this page. If not sure what to enter, call the ISP
Fortunatelly my problem was solved, Thanks. Anyway, do you know how is it possible, that I have 50Mbit-net but over wifi with speedtest I can only mesaure 17Mbit- and with my mobile it goes up to 19Mbit-. How is it possible?
Can you help me?
Thanks.
How is it possible, to configure to channel N? I’ve tried with the quick set, setting up 2Ghz only N- but after that I could not connect to the internet. I’ve heard that if Im using N-not G then I can get nearly 50Mbit-net not just 17 or 19. thanks
