HaP Lite - brick
Hi all,
i want to install updates to HaP lite, default version was 6.34 target 6.37 . But after reboot i can not connect to device. I tried NetInstall recovery, it finished with “OK” status, but i still can’t connect. I tried both 6.34.6 and 6.37 files. Is there any way how to fix it? Thank you very much.
How are you getting in? Use ether2 and make neighbor search with winbox 3.6. Then use found mac address to connect with default user credentials.
It works! Thank you very much :slight_smile:
