hAP Lite does't connect two devices on wifi
I have a MikroTik hAP Lite (RB941-2nd-TC) with the following settings:
-Bridge (eth2, eth3, eth4 and wlan)
-IP configured
-DHCP Server configured
-PPPoE configured
-NAT configured
-DNS configured
-Wifi configured
The problem is:
eth2-4 and wlan working fine at same time. I can use 3 devices in the eth interfaces, but in wlan i just can connect 1 device, if I try connect a second device I have the message “Can’t connect”
Someone can help me?
Did you do configuration by hand, or used Quickset? Try to do a configuration reset and see if it helps. By default, if you use “Home AP” mode in Quickset, there is no limit to how many devices can connect.
I did it manually.
Thanks, this worked. Now I can connect more devices.
