Hap lite error: not enough space for update.
I am trying to upgrade my hap lite but i get the ERROR: not enough disk space, 7.3MiB is required and only 0.3MiB is free .
Last time i got the same error i used Netinstall to reformat and install OS.
Now i need to update again but i get the same error, using every time the netinstall and reformating the router its not an option for obvious reasons :confused:
I am inclunding the ss of the files section if anyone can help .Thanks
If you drag and drop the file to “files” tab (Not inside “files” window) and you got the same error. Must do Netinstall.
Regards.
Delete these 2 routeros-smips files and you’ll be able to run update.
I did a configuration backup and deleted everything in files…
After deleting the files i got 9.5mb free ,the updates was 7,5mb so i tryed and was updated successfully .
Thank you all.
