if you can put it into netinstall mode and run netinstall - what did fail specifically? did Netinstall start the procedure, or was there some kind of error ?
actually we have a similar problem
Model: RouterBOARD 941-2nD
Firmware: 3.19, updated to 3.22
MikroTik RouterOS 6.25, updated to 6.28
wireless band: 2GHz-B/G/N
security profile: WPA2 PSK | AES CCM | Pre-shared key
My devices: android Samsung note 2/3 and Lenovo T410/420/430 are getting connected and in a few seconds are loosing connection.
What details would you need in order to identify if there is a problem on my side or a proble with the latest version of OS/Firmware.
PS:
it was working just fine with MikroTik RouterOS 6.25 and Firmware: 3.19
if you want to reset this, press the reset button while router is booting up and release it on the first blink of green light on the place written word “ACT”.
i also face this problem when i want to reset the router. i pressed reset button more than five seconds.
It sounds like RouterOS did not boot up because of a known software
problem, which is fixed in RouterOS v6.28. Configuration reset with
button will not fix the bootup failure. Instead netinstall should be
used to reinstall RouterOS to newest version.
I had this issue too, couldn’t reset it. Followed the manual closely. Winbox would detect it with IP 0.0.0.0 but I couldn’t connect to it via mac address.
i installed netinstall and router os for hap lite .. My Problem That when i press install it takes a few seconds then says ready again ..
please help me what is my problem here it does not accept the OS .. i reboot manually but nothing happened and the router does not give mac address or ip address on any port it is invisible for the winbox but i can see it on netinstall only .!
I have the same problema.Cuando try to update the hap lite to the new version 6.35.1 , the router disappears. I can not access it via telnet or winbox not appear your mac address .
Try using netinstall to install the firmware , and software recognize it, but when I press install , after a few seconds, the ready status again , and does not load the new firmware.
I try to manually restart , but still can not access it.
Resolved: netinstal Download version 6.30.4 and the corresponding firmware , and when you upgrade worked properly with the normal procedure netinstall .
Tip: use this version is available until another bug free .
I have upgraded a lot of hAP lite’s and I think there was exactly one time where it worked using the easy method of dragging and dropping the new package files into winbox and rebooting. All other times I had to resort to Netinstall in order to fix the bricked device. Seems like there may be an issue with the processor architecture, though I have seen the same problem pop up sometimes with the hEX lite.
2.23 bootloader and therefore ROS like 6.30 should be considered absolyte minumum for devices with latest qlacomm SoC inside(both mipsbe and smips based).
