Hello, there.
I’ve just set up my mikrotik router, and I saw that this is capable for vpn
Here you can see the picture.
And I shared some folders so other computers which are on the same network can also see the folders.
But when I tried outside the network with vpn, then it failed…
I set up the vn connection: in control panel I’ve created a new home/work connection with the vpn’s address (for the host) and username, password as well.. But unfortunately its not working.
Any solution?
Thanks in advance.
