hAP LIte no default configuration after reset
Hello
I’m resetting my hap lite ros 6.33.3 and i couldn’t get the device to have the default configuration. The router restart with no config. Is it an issue ? Thanks for your support.
This is fault for sure. Should be corrected by netinstall. But anyway, I would like to have such behaviour on all of the devices.
Does someone have the default config script available?
Do netinstall. It will make the defaults too.
My laptop firewall doesn’t allow netinstall to work properly. Bootp is filtered and i can’t disable it. Corporate policy
I am sorry. You’ll need to get other pc then.
