hap lite only has pwr light ethernet not working has no lights and doest have wifi
I cant connect to the ethernet cause its not working And the is no wifi the ethernet also has no lights on it even if it is connected my device is a hap lite please help me fix this problem for details you can look on the photo
i think, it is due to the fact that you had tried to power it up by POE.
What POE?
How can i fix it
In other thread you had written that you had tried "to power it up by Ethernet ". Hap lite doesn’t support it. if you really tried to power it by Ethernet it looks like you had broken it
How can i powee it with ethernet?
Don’t discuss one thing multiple times.
http://forum.mikrotik.com/t/do-hap-lite-only-work-with-5volts-power-cable/120017/1
