hAP Lite poor wireless performance
Hello guys, i bought a hAP lite but i am afraid that the wireless performance is poor. I have a 30Mbit connection the modem is synced in 29993Mbits but the performance i got from the hAP wifi is the one shown from speedtest. I have no problem with the ethernet though.
I have also attached my configuration can you please check it and tell me if i am doing something wrong..?
Thank you
Speedtest : http://www.speedtest.net/result/4757663763.png
add admin-mac=4C:5E:0C:E7:AD:F8 auto-mac=no name=bridge-local
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=10 band=2ghz-b/g/n disabled=no \
    frequency=auto frequency-mode=superchannel max-station-count=30 mode=\
    ap-bridge ssid=MikroTik-MyHOME wireless-protocol=802.11
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
    ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
    ether4-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
set [ find default=yes ] authentication-types=\
    wpa-psk,wpa2-psk,wpa-eap,wpa2-eap eap-methods="" mode=dynamic-keys \
    wpa-pre-shared-key=wpa2-pre-shared-key=
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=ether1-gateway
add address=192.168.1.11/24 comment="default configuration" interface=\
    bridge-local network=192.168.1.0
add address=192.168.88.0/24 comment="default configuration" dns-server=\
    192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" disabled=yes protocol=icmp
add chain=input comment="default configuration" connection-state=\
    established,related disabled=yes
add action=drop chain=input comment="default configuration" disabled=yes \
    in-interface=ether1-gateway
add chain=forward comment="default configuration" connection-state=\
add action=drop chain=forward comment="default configuration" \
    connection-state=invalid disabled=yes
    connection-nat-state=!dstnat connection-state=new disabled=yes \
add action=masquerade chain=srcnat comment="default configuration" disabled=\
    yes out-interface=ether1-gateway
/system clock
set time-zone-autodetect=no
/system routerboard settings
set cpu-frequency=650MHz
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=wlan1
Do you have both chains enabled? Can you use wide channel mode? What is the reason for superchannel mode? Can you use short guard interval?
Why antenna gain is set to 10?
Set antenna gain to 0.
Thank you for your answers.
First yes i have enabled both chains. No reason for superchannel i just did some tests i have set it back to regulatory_domain. As far as the short guard interval i cannot set a specific value i just have it to long now. Antenna gain was also for testing i set it back to 0 again.
After these my speed improved quite a bit i am getting now about 20Mbits.
http://www.speedtest.net/result/4757801889.png
Use wide channel and watch the clients registration tabs to see how the Ap is talking to the client. Also check the abilities of the client…
