hAP Lite - Port 4 Causes Switch to Not Work At All
This is a really interesting one. When I have port 4 enabled on my hAP lite, the switch stops working after a little bit. Additionally, the port shows “running” in the UI even though nothing is connected to it. And the light on the port is on and flashing. This even happens after a reset.
Here’s a complete export (with port 4 disabled):
[admin@MikroTik] > export
# jan/02/1970 00:12:37 by RouterOS 6.38.7
# software id = 5NVJ-80F8
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] disabled=yes master-port=ether2-master
add admin-mac=64:D1:54:44:38:98 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-44389B wireless-protocol=802.11
/ip neighbor discovery
set ether1 discover=no
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether2-master
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.88.0/24 comment=defconf
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=ether1
add action=accept chain=forward comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=ether1
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
Is this a software issue, or do I have a faulty device?
To be clear, when I say that the switch stops working, I mean that I can connect to the device over wifi, but I cannot ping any of the devices connected to the switch. And the devices on the switch cannot ping the router.
Interestingly, this log entry seems to coincide with when the switch stops working:
Aug 16 12:15:36 mikrotik interface,warning ether2-master: bridge port received packet with own address as source address (64:d1:54:44:38:98), probably loop
Anyone from Mikrotik have any ideas on this? I still have not been able to solve it. It happens on bugfix, current and rc.
What devices do you have connected to router? Do you have any switch connected with two cables to the router on port ETH4 and ETH2?
Do you have VMWare Workstation installed or other software which could bridge your WiFi and Ethernet interfaces on PC and therefore could make a loop if you are connected with ethernet port and WiFi at the same time?
This would happen even if I had nothing connected to the switch at all.
I replaced the device and loaded a backup onto the new device and everything seems to be working fine. I’m going to chalk it up to faulty hardware.
I just ran into the same issue… bummer. Sounds like maybe my unit is toast. It did it all of the sudden, no movement, light use, stable firmware.
I’ve reset to defaults several time without luck. Nothing is even plugged in and the port light is on.
That’s a broken physical port.
Disable the port and you can use it normally.
