Re https://mikrotik.com/product/RB941-2nD-TC, the manual says
You can use any standard 0.5-2 A USB adapter that usually comes with smartphones.
One 5 V 0.7 A USB charger is included in the box.
I would like to get a power supply with an on/off button.
Something like this: https://www.aliexpress.com/item/32802468218.html
It seems 5 V 3 A or 2.5 A are the most common.
Is it OK to use those with the hAP lite, although the manual says 0.5-2 A?
