hap Lite rest factory
Hi there
i config hotspot of mikrotik and then i change the mikrotik hostspot login file and i cant access to mikrotik managment,
i want to reset factory but i cant,
i do the structure but after a few minute the mikrotik trun of with the same config
Copy from → http://wiki.mikrotik.com/wiki/Manual:Password_reset
Using: unplug the device power, hold the button, apply power and wait until the USER LED starts flashing. Now release the button to clear configuration.
Note: If you wait until LED stops flashing, and only then release the button - this will instead launch Netinstall mode, to reinstall RouterOS.
i open the the packe there is not jumper in this case
Unplug the router board separate from power, keep the reset button pressed while you’re router board supplies, keep the reset button until the user led starts flashing. If you continue to press the reset button until the led stops flashing and then release it, enable the netinstall mode.
It dosnt work, i try it more than 10 once, i also have no access to all management page of mikrotik
In that case.
Try recover with netinstall procedure.
Caution you lose all your settings that you made
http://www.wirelessinfo.be/index.php/mikrotik/pages/netinstalle
