Hi have got Hap Lite RouterBOARD 941-2nD. My problem is when I try to connect any device to wlan, the router restarts.
This the information of the router:
Firmware type: qca9531L
Factory firmware: 3.39
Current firmware: 6.42.6
Upgrade firmware: 6.42.6
So, I don’t understand what is the problem with the router’s wifi
Hi, I changed the power supply of the mikrotik, the original power supply is 5V 0.7A. The new power supply is now 5V 1A. So far mikrotik does not restart. So I think, wlan consumes more A and the original charger can not provide that A so V goes down and then the mikrotik restarts.
But until now it seems to be working without restarts with the new charger
Current product page specifies 5V 1A power adapter as included part. Could be that this had been changed in the past. Or that you were unlucky to get false power adapter when purchasing your hAP lite.
It’s bad. Because the power supply is 5V 0.7A. I had unlucky to get false power adapter when I bought hAP lite.
It’s the information about power adapter:
SAM S4/S3
Brand EAGLE (power adapter shows an eagle)
model PW-3ZT
input 100-240v 50-60hz 6w max
output 5v 0.7A
