hi, it’s a great little router BUT damn the green LEDs are like a torch in the night and they are seen thru the ventilation holes in the case…
is there any way to have them disabled?
black tape and its done
suffer 4om that myself too, MUCH
thanks to LED’s tech advance - EVERYthing in IT hw - become “miniature projector/searchlight”.
display buttons, motherboard(usually many of many colors), coolers, harddrives(especially external. sometimes like “christmass tree”. crashy s.., man !!) routers - eventually had as bright LED’s too(relying on average “off the shelf” things as other manufacturers do). heck, even my mice - had 9 (9, Carl !!! 9 !!)LED’s, whose can be easily disabled for ..(insert by you taste) sake.
in out-door in urban area - its affected too. check “light pollution” or hygiene-relevant light intensity/proximity/directions resctritions(usually daytime-bound/tweaked), violated on persistent basis aswell.
I think you can disable the led’s by removing all entries under system —> led’s menu
i have 0 items under that menu.
hAP lite have only “user-led”. I’ve seen only one device, when ALL leds can be configured (except power, of course) — mAP.
