hAP lite user/power led
Hello!
I have hAP lite (RouterBOARD 941-2nD). Everything work,lan ports leds show activity,but user/power led don’t show any activity. It is normal situation ?
Why do you mean by “activity”?
User led is a light assigned for custom purpose. It can be turned on and off using scripts or assigned role of any other leds. I often use it as EoIP activity indicator.
You can play with leds under System > LEDs if you’re using Winbox or WebFig. In console leds are controllable in similar location at /system leds.
Power led won’t turn on when plug in power to hAP lite.
