hAP Lite wireless channels missing?
Hi
I have a hAP Lite deployed at a customer site. They have requested I change the wireless channel to 11. No problem I thought, I’ll just log in and change it.
Tried to set frequency=2472 via ssh but the hAP wasn’t having it. Strange.
Logged in via web instead and the drop down list of frequencies has 2412-2442 available, then 2447 and 2452 greyed out. No sign of anything above that.
I have regulatory domain set to ‘united kingdom’ where the channels should be available. Have also tried changing to ‘no country set’.
If I scan for other wireless networks I see APs on channels above 2452 so the radio must be able to tune that high.
Am I missing something obvious here?
Thanks, Chris
change channel width to 20mhz channel or 20/40mhzCe or 20/40mhzeC
Hi
Thanks for this. I changed from Ce to eC and the frequencies appeared. I’ve no idea what this change does. Is there a plain language explanation of what this setting does anywhere? Nothing I found via Google explained what the difference is.
Chris
some years ago we only have 802.11a and 802.11g both are 20mhz channel only
with the appearance of 802.11n one of the improvements was the possibility of using 40mhz channel, but to maintain compatibility with old stuff (i think) is not a real 40mhz channel, its a 20mhz + 20mhz channel where a first 20mhz channel its the main or central channel and the second 20mhz channel its an extension channel :confused: hard to explain beyond that.
the Ce means Central 20mhz channel its below extension 20mhz channel
the eC means Central 20mhz channel its over extension 20mhz channel
for example using a channel 6 (2437 mhz) as a central channel in Ce mode the extension channel will be channel 10, but in eC mode the extension channel will be channel 2.
your situation was that using Ce mode you only can use channel 1-7 as central channel on the available spectrum on 2,4ghz, as well on eC mode you can only use 5-11 central channel
Thank you for the detailed explanation Chechito!
The client has come back saying that since the change he is unable to connect to the wireless network. Are there any compatibility issues that surround changing from eC to Ce? My guess is no as it sounds like every access point must switch modes in order to use the higher channels but interested to hear your opinion.
It is a remote site hence why I can’t check it myself; I have to rely on the client to test and then come back to me. Maybe I need to configure a hAP here so I can test it myself!
Chris
You should really stick to 20 Mhz channel width on 2.4
Nick
check your country configuration on wireless settings
totally agree better check to have both chains enabled to improve performance, on hap lite sometimes default only enables first chain
