Hap Mini - All traffic over VPN
Hi
I have a Hap Mini configured as a simple switch (so eth1 connected to ISP router with eth2 and eth3 connected to other devices) and wireless AP with routing and DHCP handled by ISP router. I’ve also set up a L2TP VPN Client which connects successfully. As a starting point, i’m now trying to get all traffic that goes through the Hap Mini (i.e. eth2, eth3 and wireless) to go through the VPN tunnel. I tried to adapt the tutorial here (https://www.youtube.com/watch?v=gXBXTWy62X8) for the case of not using a connection mark or routing mark and only a single VPN tunnel as opposed to a list as i assumed that since i want to send all traffic through the VPN, connection and routing mark aren’t needed but the traffic doesn’t seem to go over the tunnel. Below is the configuration without a connection mark and routing mark:
# aug/24/2021 00:00:16 by RouterOS 6.42.7
# software id = BKEZ-U2KK
# model = RB931-2nD
# serial number = ZZZZZZZZZZ
add fast-forward=no name=bridge1
/interface l2tp-client
add connect-to=XXX.XXX.XXX.XXX disabled=no name=l2tp-out1 password=XXXXXX user=XXXXXXX
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=profile1 \
    supplicant-identity="" wpa-pre-shared-key=XXXXXXXXXXX wpa2-pre-shared-key=XXXXXXXXXXXXX
/interface wireless
set [ find default-name=wlan1 ] disabled=no frequency=2447 mode=ap-bridge security-profile=profile1 ssid=MikroTikvpn
add bridge=bridge1 interface=wlan1
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=bridge1
add action=masquerade chain=srcnat out-interface=l2tp-out1
add distance=1 gateway=l2tp-out1
/system routerboard settings
set silent-boot=no
When that didn’t work i also tried with what seemed to be default connection and routing marks but again no luck! Below is the configuration with connection/routing mark:
# aug/23/2021 23:57:17 by RouterOS 6.42.7
# model = RB931-2nD
/interface wireless
/ip dhcp-client
add action=masquerade chain=srcnat connection-mark=no-mark out-interface=l2tp-out1 routing-mark=main
set silent-boot=no
Can anyone please help with what the issue might be? Is it the firewall NAT and routes? or maybe something else?
Thanks!
As you are trying to pass all traffic over vpn. No need to mark packets. Skip the marking part.
Configure as follows
  1. Create l2tp client interface and connect
2 Go to IP>Firewall>Nat
create add chain=srcnat src-address=your lan ip pool out-interface=vpn_interface action=masquerade
That didn’t work unfortunately! I modified the NAT entry as suggested and included the local IP of the device from which i am testing this as follows:
add action=masquerade chain=srcnat log=yes out-interface=l2tp-out1 src-address=192.168.0.76
Full config below WITHOUT route:
# aug/24/2021 10:12:39 by RouterOS 6.42.7
# model = RB931-2nD
add connect-to=XXX.XXX.XXX.XXX disabled=no name=l2tp-out1 password=XXXXXXXXXX user=XXXXXXXXXX
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=profile1 supplicant-identity="" wpa-pre-shared-key=\
/interface wireless
/ip dhcp-client
set silent-boot=no
Output of /ip route print WITHOUT route set up:
[admin@MikroTik] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 ADS  0.0.0.0/0                          192.168.0.1               1
 1 ADC  192.168.0.0/24     192.168.0.65    bridge1                   0
 2 ADC  192.168.222.1/32   10.194.112.230  l2tp-out1                 0
Full config below WITH route:
# aug/24/2021 10:27:31 by RouterOS 6.42.7
# model = RB931-2nD
/interface wireless
/ip dhcp-client
set silent-boot=no
Output of /ip route print WITH route set up:
 1   S  0.0.0.0/0                          l2tp-out1                 1
 2 ADC  192.168.0.0/24     192.168.0.65    bridge1                   0
 3 ADC  192.168.222.1/32   10.194.112.230  l2tp-out1                 0
Unfortunately i still can’t get this to work having returned to it after some time - Can anyone please advise? Thanks
I’ve tested following advice on my setup - it works. I assume your router is connecting to a L2TP VPN server which has a public IP address.
First, change the Distance on your Internet default route to some higher number*:
  • dst-address=0.0.0.0/0 | gateway= | distance=3
Second, set up static route for public IP of L2TP VPN Server, make sure you use lower number for Distance, e.g.:
  • dst-address= | gateway= | distance=1
Third, ADD new default static route, make sure you use in-between number for Distance, e.g.:
  • dst-address=0.0.0.0/0 | gateway=l2tp-out1 | distance=2
*if you use DHCP on WAN interface, you can change the distance in DHCP Client > Interface > Default Route Distance:
ip dhcp-client set interface=ether1 default-route-distance=X
In order for this to work, you need to have Masquerade NAT set up for L2TP traffic:
  • chain=srcnat | action=masquerade | out-interface=l2tp-out1
If you are using the hAP purely as a switch, your clients will all be getting their routes and IPs from the ISP router, and will send all their traffic via that route.
What you will need to do is use the routing capabilities of the hAP, having ether1 as the WAN interface, getting an IP from the ISP router, and the switch with ether2, ether3 and wlan sending all their traffic to the hAP, for it to route via the VPN.
Also make sure you have a route to the VPN server IP going through the ISP gateway if you set the VPN end point as the default router.
