hAP mini (RB931-2nD) cannot /export configuration
I recently upgraded some of my routers to RouterOS 7.1 stable. Most of the things work fine out of the box. I hit a problem when I tried to use /export command on hAP mini (RB931-2nD). I tried it on two different devices with completely different configurations. Every time the /export freezes after approximately 23 lines. My guess is that it could be caused by the limited hardware resources of this router.
Does the /export command work for you on this router or do you have the same problem?
I had the same problem with this device on version 7.1rc6. It took a very long time to complete (>3h)
After the update to “7.1 testing” the problem disappeared.
So, I would try a configuration reset.
N
That’s quite a long time :slight_smile: . I didn’t have that much patience. I’ll try to give it more time.
N
I tried that. One of the hAP minis had configuration reset after upgrade to 7.1.
Thanks anyway! At least I know that the problem is not on my side.
