Was playing around with a HAP mini today, first thing I did was reset config and selected do not do backup and no default config.
Device was on 6.41.2, I then downloaded the smips package (6.41.3) and tried to copy the update package to device, but get to about 5Mb of file transfer, CPU hits 100% and then I lose connection, tried a couple of time same result.
So then I connected device via WLAN to my home network and did the upgrade that way, again I noticed CPU was hitting 100% but did not lose connection this time, looked at profile and noticed that a service “spi” (Stateful Packet Inspection) was using 75% of CPU.
Keep in mind I did a reset of config with no default config prior to this, so I am a bit confused, there are no firewall filter, NAT, Mangle or RAW rules, where does the spi come into play with this config and why will the spi be so high?
Maybe a bug in ROS??
