can I power a hAP using a 802.3af switch port (Cisco SG300-10p)?
Thanks!
Thanks!
No.
Thanks!
You should check the datasheet so it mentions 802.3af/at.
When it only says PoE it is not compatbile with 802.3af/at (in case of MikroTik and other lowcost devices).
802.3af/at capability is only available on newer devices like cAP AC.
You could use converters like these from Ubiquiti:
https://www.ui.com/accessories/instant-8023af-adapters/
