hAP
Hello to all
I have hAP for may small office and he is set like AP (all ports Lan1-Lan4 and WLan1 are bridge) so from Wifi a have access to Printer, NAS, CCTV…
Now I like to have Guest Wifi (virtual AP) which gives ONLY Internet to clients so they can’t see anything on LAN (CCTV, NAS, PC-s.
Is this possibe to set ? Becaouse my hAP is not Router is just AP.
I add virtual AP,
Give network address to that Virtual AP (192.168.5.1/24 network 192.168.5.0)
Make DHCP Server for Virtual AP
Make masqurade on Virtual AP
Add Firewal Filter drop for my internal lan address (192.168.1.0/24 and 192.168.5.0/24)
and oposite (192.168.5.0/24 and 192.168.10/24)
All fork fine, from my Wifi a have internet, and DHCP (main Huawei Router DSL) gives me address 192.168.1.6/24
When I connect to Guest Wifi, DHCP gives me address 192.168.5.254 BUT I DON’t HAVE internet access, I can’t open any web site. :frowning:
Any advice or help please ?
can you ping the AP from the guest network?
What DNS server do you use for the guest network - maybe the problem is that you block the DNS traffic from the guest network?
Solved…
After reboot I start to work… All work fine :slight_smile:
