HapAC-Lite and wAPac issue
I’m trying this setup Hapac-Lite connect to a wAPac.
wAPac is connect on port 5 through POE.
I use a 24V 1.2A powersupply. to power that.
After a couple of minutes, the hAC-lite is unresponsive and bricked.
I’ve to restore it to make it work again. (Netinstall) but it crashed again.
I don’t know what is happening and i’m unable to make a supout because the Hapac
any though ?
No idea? Both are running 3.7.1
very strange issue, hoy is your PoE configuration on ether 5 of hap AC lite??
y have tested poe output to power 3 hap ac lite daisy chained without problem even with cpu maxed at 100% and all radios at max tx power; when i add a fourth daisy chained hap ac lite and test with cpu maxed out the first hap ac lite disable poe because of overcharging without any issue, in my case PoE interfaces are configured in auto ON mode.
