I’m having trouble getting my hAPac Lite to work with vlans.
Here’s the switch config:
# may/27/2018 15:25:51 by RouterOS 6.42.3
# model = RouterBOARD 952Ui-5ac2nD
add ports=ether1,ether5,switch1-cpu switch=switch1 vlan-id=1
add ports=ether1,ether2,ether3,ether4,switch1-cpu switch=switch1 vlan-id=20
# SWITCH VLAN-ID PORTS
0 switch1 1 ether1
ether5
switch1-cpu
1 switch1 20 ether1
ether2
ether3
ether4
switch1-cpu
# may/27/2018 15:26:18 by RouterOS 6.42.3
set 0 default-vlan-id=1 vlan-header=add-if-missing vlan-mode=secure
set 1 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 2 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 3 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 5 vlan-mode=fallback
# NAME SWITCH VLAN-MODE VLAN-HEADER DEFAULT-VLAN-ID
0 ether1 switch1 secure add-if-missing 1
1 ether2 switch1 secure always-strip 20
2 ether3 switch1 secure always-strip 20
3 ether4 switch1 secure always-strip 20
4 ether5 switch1 disabled leave-as-is 0
5 switch1-cpu switch1 fallback leave-as-is 0
I’ve left ether5 unconfigured in order to access it.
So basically, when ether1 is connected and ether5 disconnected, the device cannot pick up a DHCP lease - the RB3011 just states ‘offered’
When ether5 is connected and ether1 disconnected,ether5 picks up an IP from the RB3011 is expected.
What puzzles me is I have the exact same config on my hAPac & RB750 and it works fine.
