hAPac stuck bootloop
Hello, thanks for reading, I’m a newbie. I tried to upgrade firmware and the power went out. The firmware is corrupted and now RouterOS doesn’t start because it resets again and again. I tried to use netinstall but the program doesn’t detect it (i tried to reset it, changed the gateway and adapter settings, nothing worked) so I figured that that’s not possible. I was wondering if there is a way using some kind of protocol to transfer the files for it to start. Thank you very much.
This is exactly what netinstall does. But it is very fragile, you have to follow all the tiny details mentioned in netinstall manual. And keep trying.
