hAPac2 as Wireless Network Bridge
I am having difficulty trying to se up a hAPac2 as a wireless bridge. I’m certain I’ve done this in the past, but I can’t find any saved .rsc files that I usually export from every device config I do, so I may only be remembering the various hotel bridge configs I have used that have routing functions, typically on a hAPac or mAP lite. I’ve read quite a few posts, and then had to create a new login as it seems my old login must have been deactivated as I haven’t been logged in quite a while, but I’m not new to the forum.
I want to connect to an existing wifi network, and have devices connected to the ether ports get their dhcp address from the main network. I have a hAPac at home as my main wifi AP (with a HEX for a router), and I am able to make the hAPac2 work as I want when connecting to the hAPac, using the config as follows:
add authentication-types=wpa2-psk eap-methods=“” mode=dynamic-keys name=
profile1 supplicant-identity=“” wpa2-pre-shared-key=KEY
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no frequency=auto
mode=station-bridge security-profile=profile1 ssid=SSID
wireless-protocol=802.11
add bridge=bridge1 interface=wlan1
/ip dhcp-client
add disabled=no interface=bridge1
With this the bridge gets it’s IP address, and I can see that my laptop connected via an ether port to the hAPac2 gets an IP address from the HEX. So it works fine connecting to another Mikrotik it seems. When I try to connect to a different network (Ruckus AP, RB4011 router), I get an IP on the bridge, but cannot get an ether connected device to get an IP. I’ve tried ap-bridge, ap-pseudobridge, and a host of other stabs in the dark.
Is there something about the device or an obvious setting that I am missing that is preventing a connection? I’m hoping to use the hAPac2 as a bridge for a couple of components where running an ethernet cable is not feasible.
Thanks for any help.
Station-bridge is a proprietary Mikrotik mode that will not work with non-Mikrotik devices. In “station-bridge” you get essentially a transparent bridge but this doesn’t work with non-mikrotik hardware.
station-pseudobridge should do.
See here:
https://wiki.mikrotik.com/wiki/Manual:Wireless_Station_Modes
Pdanger???
Ruckus uses directed DHCP.
Buy an H510 and move on.
Looks like that did get the modem/router and hAP AC2 connected. I confirmed by looking at the device list on the modem/router and finding the MAC of the hAP AC2. My device attached by ethernet to the hAP AC2 was not getting an address assigned, but I was able to make a static address and get a connected. Would setting up a DHCP Relay and pointing it to wlan1 help this?
Hey, yes it is. H510 as a bridge you’re saying? Was trying to bridge something on the cheap for a family member.
Ok, yes, I thought I remembered one of the modes was a Mikrotik thing, obviously that’s why it connected nicely to the hAPac.
Thanks all for the replies.
Directed DHCP specifically RESTRICTS multiple IPs going to one device. Like the Virtual Machine on a MAC. Or the devices connected to “repeaters”.
Turn off Directed DHCP… which ain’t as easy as it used to be in ZD… or… buy the H510 and join it to your unleashed network YOU CHEAP MF!!!
(Welcome to the forum BTW.)
