I’ve probably done something wrong, but I have a netinstalled HAP ac2 (international non locked version) with wifi-qcom-ac
/interface wifi
set [ find default-name=wifi1 ] configuration.mode=ap
set [ find default-name=wifi2 ] configuration.mode=station
/ip hotspot profile
/system note
set show-at-login=no
The issue is when I run a scan on my 5ghz wifi2 interface I can see my access points (Cap AX) running on 5220 (furthest away with a -97 signal), but I cannot see the ones running on 5745 (1 meter away). They just don’t show up on the list and therefore when I try to connect to them as a station bridge it does not work.
I can connect to the 5745 access points via android mobile and laptop, just not via the HAP ac2, which I’m wanting to use as a station bridge switch.
Have I done something stupid?
Thanks,
Chris
