HAPac3 with VLANs and QCOM-AC Capsman
I’m trying to switch my current HAPac3 + HAPac2 CAPSMAN setup from Wireless to QCOM-AC to get (amongst others) fast roaming working. I have a setup on my current system with Wireless which works and has 4 SSID’s, all going to separate VLANs. Works well, but roaming with an access rule is not nice. Sometimes the switch-over is just too long. I read the documentation on https://help.mikrotik.com/docs/display/ROS/WiFi#WiFi-CAPsMAN-CAPVLANconfigurationexample: to get it going but I keep on not getting it to work. I executed the following script after a factory reset:
#disable 2nd Mikrotik powered off ether5
/interface ethernet poe
set ether5 poe-out=off
#rename bridge "bridge" to "br" to follow example
set bridge name=br
# do not add "vlan-filtering=yes" as this is not supported by the Atheros8327 switchchip
/interface vlan
add interface=br name=MAIN vlan-id=10
add interface=br name=GUEST vlan-id=20
/interface wifi datapath
add bridge=br name=DP_AC
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk ft=yes ft-over-ds=yes name=Security_MAIN passphrase=HaveAg00dDay
add authentication-types=wpa2-psk,wpa3-psk ft=yes ft-over-ds=yes name=Security_GUEST passphrase=HaveAg00dDay
/interface wifi configuration
add datapath=DP_AC name=MAIN_AC security=Security_MAIN ssid=MAIN_Network
add datapath=DP_AC name=GUEST_AC security=Security_GUEST ssid=GUEST_Network
# add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.254 (as it is marked as disabled in the next set of commands)
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool2 ranges=192.168.20.2-192.168.20.254
# add address-pool=dhcp_pool0 disabled=yes interface=br name=dhcp1
add address-pool=dhcp_pool1 interface=MAIN name=dhcp2
add address-pool=dhcp_pool2 interface=GUEST name=dhcp3
remove [ find interface=wifi1 ]
remove [ find interface=wifi2 ]
#to remove pre-existing wifi1 and wifi2 on bridge by default config
/interface bridge vlan
add bridge=br tagged=br,ether5,ether4,ether3,ether2 vlan-ids=20
add bridge=br tagged=br,ether5,ether4,ether3,ether2 vlan-ids=10
/interface wifi capsman
set enabled=yes interfaces=br
/interface wifi provisioning
add action=create-dynamic-enabled master-configuration=MAIN_AC slave-configurations=GUEST_AC supported-bands=5ghz-ac
add action=create-dynamic-enabled master-configuration=MAIN_AC slave-configurations=GUEST_AC supported-bands=2ghz-n
#add address=192.168.1.1/24 interface=br network=192.168.1.0
add address=192.168.10.1/24 interface=MAIN network=192.168.10.0
add address=192.168.20.1/24 interface=GUEST network=192.168.20.0
#add address=192.168.1.0/24 gateway=192.168.1.1
add address=192.168.10.0/24 gateway=192.168.10.1
add address=192.168.20.0/24 gateway=192.168.20.1
/system identity
set name=cAP_Controller
/interface wifi
set [ find default-name=wifi1 ] configuration.manager=capsman disabled=no
set [ find default-name=wifi2 ] configuration.manager=capsman disabled=no
add disabled=no  master-interface=wifi1 name=wifi21
add disabled=no  master-interface=wifi2 name=wifi22
#changed bridgeLocal to br as it is the same unit
add bridge=br interface=wifi1 pvid=10
add bridge=br interface=wifi21 pvid=20
add bridge=br interface=wifi2 pvid=10
add bridge=br interface=wifi22 pvid=20
add bridge=br untagged=wifi1,wifi2 vlan-ids=10
add bridge=br untagged=wifi21,wifi22 vlan-ids=20
/interface wifi cap
set discovery-interfaces=br enabled=yes slaves-static=yes
After provisioning locally I see the following appear:
[admin@cAP_Controller] /interface/wifi> print
Flags: M - MASTER; B - BOUND; I - INACTIVE
Columns: NAME, MASTER-INTERFACE, CONFIGURATION.SSID
#     NAME   MASTER-INTERFACE  CONFIGURATION.SSID
0 MB  wifi1                    MAIN_Network
;;; DFS channel availability check (10 min)
1 MB  wifi2                    MAIN_Network
2  B  wifi2  wifi1             GUEST_Network
3  BI wifi3  wifi2             GUEST_Network
So twice wifi2 in the interfaces and no sign of the configured wifi21 and 22
Phone connecting to MAIN_Network gets 192.168.88.252 (normal IP range for Mikrotik) and is registered on wifi1
Phone connecting to GUEST_Network gets 192.168.88.250 (normal IP range for Mikrotik) and is registered on wifi2 (seems to be the slave interface of physical interface wifi1)
So at least the documentation is off.
After playing around in the WinBox GUI I now have this setup:
# 2024-06-12 23:21:42 by RouterOS 7.15.1
# software id = ****-****
# model = RBD53iG-5HacD2HnD
# serial number = ************
add admin-mac=**:**:**:**:**:E5 auto-mac=no comment=defconf name=br
add disabled=yes name=bridgeLocal
set [ find default-name=ether5 ] poe-out=off
/interface vlan
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk,wpa3-psk ft=yes ft-over-ds=yes name=\
    Security_MAIN
    Security_GUEST
add datapath=DP_AC disabled=no name=MAIN_AC security=Security_MAIN ssid=\
    MAIN_Network
add datapath=DP_AC disabled=no name=GUEST_AC security=Security_GUEST ssid=\
    GUEST_Network
/interface wifi
set [ find default-name=wifi1 ] configuration=MAIN_AC disabled=no
add configuration=GUEST_AC disabled=no mac-address=DE:2C:6E:32:CB:E9 \
# DFS channel availability check (10 min)
set [ find default-name=wifi2 ] configuration=MAIN_AC disabled=no
add configuration=GUEST_AC disabled=no mac-address=DE:2C:6E:32:CB:EA \
    master-interface=wifi2 name=wifi3
add address-pool=default-dhcp interface=br name=defconf
/disk settings
set auto-media-interface=br auto-media-sharing=yes auto-smb-sharing=yes
add bridge=br comment=defconf interface=ether2
add bridge=br comment=defconf interface=ether3
add bridge=br comment=defconf interface=ether4
add bridge=br comment=defconf interface=ether5
add bridge=br interface=*7 pvid=10
add bridge=br interface=*D pvid=20
add bridge=br interface=*8 pvid=10
add bridge=br interface=*E pvid=20
add bridge=br interface=*1C
add bridge=br untagged=*7,*8 vlan-ids=10
add bridge=br untagged=*D,*E vlan-ids=20
add comment=defconf interface=br list=LAN
/interface wifi cap
set certificate=request discovery-interfaces=br enabled=yes slaves-static=yes
set ca-certificate=auto certificate=auto enabled=yes interfaces=br \
    package-path="" require-peer-certificate=no upgrade-policy=none
add action=create-enabled disabled=no master-configuration=MAIN_AC \
add address=192.168.88.1/24 comment=defconf interface=br network=192.168.88.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Amsterdam
/system identity
/system note
set show-at-login=no
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/system script
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :foreach iface in=[/interface/wifi find where (configuration.mode=\"a\
    p\" && disabled=no)] do={\r\
    \n     /interface/wifi wps-push-button \$iface;}\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
/user group
add name=fail2ban-group policy="ssh,read,write,!local,!telnet,!ftp,!reboot,!po\
    licy,!test,!winbox,!password,!web,!sniff,!sensitive,!api,!romon,!rest-api"
add name=Fail2BAN-API policy="read,write,api,!local,!telnet,!ssh,!ftp,!reboot,\
    !policy,!test,!winbox,!password,!web,!sniff,!sensitive,!romon,!rest-api"
add name=hass-group policy="reboot,read,write,policy,test,api,!local,!telnet,!\
    ssh,!ftp,!winbox,!password,!web,!sniff,!sensitive,!romon,!rest-api"
But depending on the order I provision the radio’s, I get different results:
2  B  wifi3  wifi1             GUEST_Network
3  BI wifi4  wifi2             GUEST_Network
1  B  wifi2  wifi1             GUEST_Network
2 MBI wifi2                    MAIN_Network
The first print is after I provisioned radio 1 and later radio 2, the second is when I provisioned both at the same time. Now I’m wondering how I can be sure in which order these are provisioned after a reboot… I don’t want to have random assignments to VLANs depending on the order of provisiong. I did search on the forum, but couldn’t find anything yet.
Can somebody please point me to the definitive documentation on QCOM-AC in combination with CAPsMAN and Atheros8327?
I have the same issue with interfaces getting the same name assigned. I already filed a support ticket and I will reference this topic for evidence. Thank you
Can you send me your support ticket ID? I will make a new ticket myself and reference your ticket. That could resolve the issue of duplicate Wifi ID’s quicker
Hi @infabo,
did you get any reply from Mikrotik support? I am facing exactly the same problem as you and am wondering if there is any solution.
