hapax3 wifi 1 & 2 keep disconnecting
Good day!
I’m semi new to Mikrotik so please bear with me. I have a hAP ax3 that is running ROS 7.13 & wifi-qcom 7.13. I have set up the wifi with some very basic configurations. It doesn’t matter if I try to connect to wifi1 or wifi2 I’m getting the same associated, connected, disconnected, disassociated. I’m wondering if this stems from me upgrading the router from 7.8 to 7.12 then to 7.13. Then installing wifi-qcom 7.13. Here is my config:
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=
10min-cac .width=20/40/80mhz configuration.country=“United States” .mode=
ap .ssid=“xxx” disabled=no security.authentication-types=
wpa2-psk
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=
10min-cac .width=20/40mhz configuration.country=“United States” .mode=ap
.ssid=“xxx” .tx-power=0 disabled=no
security.authentication-types=wpa2-psk,wpa3-psk
Thanks in advance!
Try to disable management protection
