HapLite Reset
I have some problems whit the Mikrotik HapLite. How can i reset the Router ?
Have you tried to connect via winbox in mac mode?
The timing while pressing the reset button is tricky, as depending on its config, and the time you press it, you’ll enter
  • Reset mode
  • Cap mode
  • Netinstall mode
Provided you cannot connect in mac mode and do a System > reset configuration, ticking no defaults if you want a truly blank router setup, Netinstall is the last one so its the easiest to enter, and the most thorough procedure for resetting as the nand is formatted, ROS reinstalled…
Check http://wiki.mikrotik.com/wiki/Manual:Netinstall
