hapLite VLAN trunk fails with no default vlan defined.
I’m trying to get a trunk working between a hapLite and a CRS 125. The hapLite is the Atheros 8227 chipset, which should work.
I have 2 vlans (2 and 17) defined on the hap Lite. I want vlan 2 on eth1, and vlan 17 on eth 2, with the trunk on eth4 (trunked to the CRS 125)
add name=bridgeVLAN
/interface vlan
add interface=bridgeVLAN name=vlanGUEST vlan-id=17
add interface=bridgeVLAN name=vlanLAN vlan-id=2
set 0 default-vlan-id=2 vlan-header=always-strip vlan-mode=secure
set 1 default-vlan-id=17 vlan-header=always-strip vlan-mode=secure
set 3 default-vlan-id=2 vlan-header=add-if-missing vlan-mode=secure
set 5 vlan-mode=secure
add bridge=bridgeVLAN interface=ether1
add bridge=bridgeVLAN interface=ether2
add bridge=bridgeVLAN interface=ether4
add ports=ether4,ether1,switch1-cpu switch=switch1 vlan-id=2
add ports=ether2,switch1-cpu,ether4 switch=switch1 vlan-id=17
The above config works, because of this line:
A vlan 2 system on eth1 can ping across the trunk to an IP address on the CRS or laptop plugged into vlan 2 or 17 on the CRS.
However, a vlan 17 system on eth2 can’t ping across the trunk.
If I change that line to vlan 0 (or 1):
set 3 default-vlan-id=0 vlan-header=add-if-missing vlan-mode=secure
then the eth1 vlan 2 system can no longer ping across the trunk. The configs I find on line don’t specify a default-vlan-id, but in my case, if it’s not default to vlan 2, ping fails.
Ideas? that one change on the hapLite makes the trunk fail makes me think it’s on the hapLite side of the config.
Well, I though Id’ found what I’d forgotten:
/interface bridge vlan
add bridge=bridgeVLAN tagged=vlanGUEST vlan-ids=17
add bridge=bridgeVLAN tagged=vlanLAN vlan-ids=2
add bridge=bridgeVLAN interface=ether1 pvid=2
add bridge=bridgeVLAN interface=ether2 pvid=17
but it didn’t make any difference. Still doesn’t work
works for vlan 2, but I can’t change that to default-vlan-id=1.
add bridge=bridgeVLAN interface=vlanGUEST pvid=17
add bridge=bridgeVLAN interface=vlanLAN pvid=2
Now I’m probably making a mess of things, but still not helping.
When you decide NOT to use these settings I can certainly help.
As well I would have to see the complete config
/export hide-sensitive file=anynameyouwish (and just ensure no public iP addresses are displayed).
The problem my be the 8227 switch chip, if I understood what @tdk said about them in post #79 of this thread Vlan configuration issue
This is the relevant part:
On ether2 is vlan 17 untagged or tagged? Have you tried making it a pure trunk with both 2 and 17 tagged? What type of access point do you have?
I’m glad to use any settings that will work! I pulled those settings from the wiki:
https://wiki.mikrotik.com/wiki/Manual:Basic_VLAN_switching
it just won’t let me not set the default-vlan-id for interface 3 (eth4). If I set it for 2, vlan 2 works. If I set it for 17, vlan 17 works.
# jan/02/1970 20:42:13 by RouterOS 6.49.6
# software id = 2UIZ-IVIF
# model = RB941-2nD
add name=bridgeVLAN
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/interface vlan
set 3 default-vlan-id=17 vlan-header=add-if-missing vlan-mode=secure
add address=192.168.2.3/24 interface=vlanLAN network=192.168.2.0
add address=192.168.17.3/24 interface=vlanGUEST network=192.168.17.0
/system identity
set name=B941-2nD
I have a haplite. I need you to tell me if it’s tagged or untagged. :slight_smile: The config is above
In theory I want ether 4 to be the trunk.
For your security, remove serial number from export…
The entire /interface bridge vlan section and the pvid= settings in the /interface bridge port are ignored when the bridge has vlan-filtering=no.
The switching setup should work with
set 3 vlan-header=add-if-missing vlan-mode=secure
i.e. with default-vlan-id=0. Are you sure the CRS configuration is correct?
Watch this youtube video. It is using two hap lites with trunk from one to the other. The haplite on the right should be similar to your haplite, the haplite on the left is more like your CRS 125 switch.
Configuring VLAN’s on MikroTik RouterBoard using the Switch Chip by Maher Haddad.
Well, I would say yes with the obvious caveat that the darned thing doesn’t work , which means it’s broken somewhere.
Here are the configs of the two devices. I’ve removed the changes I noted, and watched the video, where I think everything is right on the hAP Lite side.
Same problem. If I set the default vlan id on the hAPLite on the trunk interface to a particular vlan, it works for that vlan only. Setting it to 0 it doesn’t work.
# jan/02/1970 21:55:47 by RouterOS 6.49.6
# model = RB941-2nD
add name=bridgeVLAN
/interface wireless
/interface vlan
/system identity
set name=B941-2nD
And the CRS
 jan/02/1970 07:30:56 by RouterOS 6.49.6
# software id = AKR0-XZSF
# model = CRS125-24G-1S-2HnD
add name=bridgeVLAN
/interface wireless
set [ find default-name=wlan1 ] disabled=no ssid=MikroTik
/interface vlan
add name=poolLAN ranges=192.168.2.100-192.168.2.199
add name=poolGUEST ranges=192.168.17.100-192.168.17.199
add address-pool=poolLAN disabled=no interface=vlanLAN name=dhcpLAN
add address-pool=poolGUEST disabled=no interface=vlanGUEST name=dhcpGUEST
add bridge=bridgeVLAN interface=ether3
add bridge=bridgeVLAN interface=ether5
add bridge=bridgeVLAN interface=ether6
add bridge=bridgeVLAN interface=ether7
add bridge=bridgeVLAN interface=ether8
add bridge=bridgeVLAN interface=ether9
add bridge=bridgeVLAN interface=ether10
add bridge=bridgeVLAN interface=ether11
add bridge=bridgeVLAN interface=ether12
add bridge=bridgeVLAN interface=ether13
add bridge=bridgeVLAN interface=ether14
add bridge=bridgeVLAN interface=ether15
add bridge=bridgeVLAN interface=ether16
add bridge=bridgeVLAN interface=ether17
add bridge=bridgeVLAN interface=ether18
add bridge=bridgeVLAN interface=ether20
add bridge=bridgeVLAN interface=ether21
add bridge=bridgeVLAN interface=ether22
add bridge=bridgeVLAN interface=ether24
add bridge=bridgeVLAN interface=sfp1
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether23,switch1-cpu vlan-id=2
add tagged-ports=ether23,switch1-cpu vlan-id=17
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=2 ports=\
    ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8
add customer-vid=0 new-customer-vid=17 ports=\
    ether9,ether10,ether11,ether12,ether13,ether14,ether15,ether16
    ether17,ether18,ether20,ether21,ether22,ether24
add ports="ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether17,ether\
    18,ether20,ether21,ether22,ether24,switch1-cpu" vlan-id=2
add ports="ether9,ether10,ether11,ether12,ether13,ether14,ether15,ether16,ether2\
    4,switch1-cpu" vlan-id=17
add address=192.168.2.1/24 interface=vlanLAN network=192.168.2.0
add address=192.168.17.1/24 interface=vlanGUEST network=192.168.17.0
add address=192.168.2.0/24 dns-server=8.8.8.8 gateway=192.168.2.1 netmask=24
add address=192.168.17.0/24 dns-server=8.8.8.8 gateway=192.168.17.1 netmask=24
/system identity
set name=RS125-24G-1S-2
With the goal to have a trunk between the two on hAPLite: ether 4 and CRS125 on ether 24 for VLANs 2 and 17, with (for the moment) full connectivity across all the ports and vlans. I’m using ether3 on the hAP to manage it, and ether 19 on the CRS, specifically so I don’t cut myself off at the knees with other configuration.
For your security, remove serial number from export… also from previous posts…
ether23 is missing from the definitions under /interface ethernet switch vlan on the CRS
I did that on my most previous post, and just did for the earlier one.
While I do appreciate your point, why does my serial make the device less secure?
Good catch, but you caught my typo, not my problem. I updated the above post to correct that my trunk should be on eth24 on the CRS. (Mikrotik has the ports upsidedown from what I’m used to)
well, the CRS had ether24 configured for Ingress VLAN translation under Switch > In. Vlan Trans, which as a trunk port it shouldn’t have? Removed it. Didn’t fix things, but perhaps a step closer.
Seeing several threads here about the Atheros 8227 chipset and VLAN issues, I replaced my hAP Lite with a hAP AC (QCA 8337 chip) and effectively dropped the config in place onto the (blank) hAP AC.
I still have that same problem. The only difference is that the hAP AC permits me to set the VLAN to blank for switch > port > ether4 on the hapAC. I’d get an error trying that on the hAP lite.
It’s clear to me that tagging is wrong somewhere, because I’m assigning a tag to ether 4 if there isn’t one, and that “add if missing” default vlan ID when added works for that vlan
		vlan-id=2	vlan-id=17	vlan-id=0
192.168.2.34 (hapAC, eth1, vlan 2)
	192.168.2.1	-	+	-
	192.168.2.3	+	+	+
	192.168.2.34
	192.168.2.100	-	+	-
	192.168.17.1	-	+	-
	192.168.17.3	-	+	-
	192.168.17.35	-	+	-
192.168.17.35 (hAP AC, eth 2, vlan 17)
	192.168.2.1	+	-
	192.168.2.3	-	+
	192.168.2.34	+	-
	192.168.2.100	+	-
	192.168.17.1	+	-
	192.168.17.3	+	+
	192.168.17.35
192.168.2.100 (CRS, eth8, vlan 2)
	192.168.2.1	+	+	+
	192.168.2.3	-	+	-
	192.168.2.34	-	+	-
	192.168.2.100
	192.168.17.1	+	+	+
	192.168.17.3	+	-	-
	192.168.17.35	+	-	-
So traffic exiting out of ether4 isn’t tagged?
Yet:
/interface ethernet switch vlan ports=ether4, ether1, switch-cpu switch=switch1 vlan-id=2
/interface ethernet switch vlan ports=ether4, ether2, switch-cpu switch=switch1 vlan-id=17
If I enable vlan-filtering on the hAP AC and CRS
/interface bridge name=bridge1 vlan-filtering=yes
I lose connectivity. Which I think makes sense, because enabling that would be using CPU instead of the switch chip.
With the gigabit atheros switch chips you should leave vlan-header=leave-as-is as described in the documentation.
Enabling VLAN filtering on the bridge will disable hardware switching, so you will not get wire-speed switching between ports, and requires the bridge port PVID and bridge VLANs to be defined. Do not attempt to mix software VLAN filtering and hardware switch configuration, they interact in undocumented ways.
If I reveal something, can be use against users…
But obviously someone can track you with that information…
