Hard reset RB450G
Hello, I add a bad configuration to my RB450G. And now I can not access to it.
How could I make a hard reset? I try to ipen the box, and do a contact in the reset pins with a metel, bit nothing happens. I makes a beep but still can not to access.
Which is the correct steps? Switc off, contact the pins, switch on, wait to the beep?
Could I reset from serial port?
I will really appreciate your help, I don’t know how to rescue my RB.
Best regards.
Wait until the router lights start flashing
Then release to be restarted
Thanks!
I press the reset until light start blinkikg and it works!
Best regards
