Hard time building transparent firewall
Hi all,
I have checked several posts giving some hints about making a transparent bridge firewall with Mikrotics. I am having a hard time getting it work.
My setup:
Router <> transparent fw <> Switch environment
CRS354 as transparent fw with next setup:
add admin-mac= auto-mac=no fast-forward=no frame-types=admit-only-vlan-tagged ingress-filtering=yes name=bridge pvid=30 vlan-filtering=yes
/interface vlan
add comment=ADM interface=bridge name=VLAN-30 vlan-id=30
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged hw=no ingress-filtering=yes interface=ether8 pvid=10
add bridge=bridge frame-types=admit-only-vlan-tagged hw=no ingress-filtering=yes interface=ether1
add bridge=bridge frame-types=admit-only-vlan-tagged hw=no ingress-filtering=yes interface=ether2
/interface bridge vlan
add bridge=bridge comment=ADM tagged=bridge,ether1,ether2 untagged=ether9 vlan-ids=30
add bridge=bridge comment=TEST tagged=bridge,ether1,ether2 untagged=ether8 vlan-ids=10
add address=192.168.88.12/24 comment=“ADM” interface=ether49 network=192.168.88.0
add address=192.168.100.110/24 comment=“ADMIP” interface=VLAN-30 network=192.168.100.0
add distance=1 gateway=192.168.100.1
After this I can use ether8 as test port and connect a laptop to test firewall; then
  • activate both ‘use ip firewall’ and ‘use ip firewall for VLAN’
  • create a simple rule like
add action=drop chain=forward dst-address=0.0.0.0 log=yes protocol=icmp src-address=0.0.0.0
Expecting the laptop not being able to ping anywhere.
I played with in/out interfaces, in/out bridges ports with no luck; obviously I am missing the rigth needed step/config.
Can you give me some hint?
Thanks in advance, best regards,
First obvious problem is that 0.0.0.0 means “exactly one address 0.0.0.0”, which nothing will ever use. If you want to match any address, it’s 0.0.0.0/0. And then you can just omit the whole src/dst-address.
