Hardware compatibility issue
I want to install such a set, but I don’t know if it will work?
S+RJ10 (https://mikrotik.com/product/s_rj10) + XQ+CM0000-XS+ (https://mikrotik.com/product/xq_cm0000_xs_) and use in switch CRS326-24S+2Q+RM (https://mikrotik.com/product/crs326_24s_2q_rm)
Thanks!
Can not comment on XQ+CM0000-XS but be advised S+RJ10 is known to get really hot.
You can not place them side by side nor top to bottom so you would loose about half your SFP-ports.
